Question about Le Chef Electric Shabbos Hot Water Pot-Free Electric Kettle
I purchased a perko urn model #107Sss and the water has a terrible metalic taste. What can i do
I bought the same horrible, cheap, dishonest unit. They disingenuously say to rinse and boil once. I've boiled the water at least twelve or thirteen times. They also brag it doesn't need immersion (not because such units don't require immersion since that will damage the unit and they don't need immersion) but because of their superior spirituality. Let them answer for dishonesty in 120 years.
Posted on Jul 08, 2010
I donated a new Platinum B70 Brewer for use by our church staff. The tap water tastes terrible and ruins the coffee flavor!
and bench top or under bench water filter in the water supply line to the unit will work
best filters to consider are one ceramic ( removes particles to a measurement of less than 1/2 micron and one carbon filter that removes all taste problems
Aug 18, 2017 | Keurig Coffee Makers & Espresso Machines
After two months the water that's boiled it still makes tea and coffee taste funny ?
What are you using for water? If you are just using tap water try buying a bottle of distilled water at the grocery store. Tap water - especially if it has Chlorine in it - makes terrible tasting coffee. Plus I'd suggest it's not good for you anyway.
You can also try the manufacturer's cleaning recommendation which typically involved running a water/vinegar mixture through the unit and then a couple of empty pots of plain water.
Last thing to check is to replace the water filter in the coffee maker if the model you have has one. Some higher end models do.
Good luck.
Mar 13, 2015 | Coffee Makers & Espresso Machines
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Bad tasting water
Do not use a steel or plastic braided supply line. They make the ice taste bad.
Dec 29, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Strong metal taste, how do I get rid of it. Coffee tastes terrible with very strong metal taste. I have boiled kettle about 8 times, but am unable to get rid of bad taste.
Professional chefs face this problem many times over with their stainless steel wares. Fill the coffee pot with water. Add a tbs of bleach. Let set for 2 hours. See if that helps. If it doesn't, please let me know.
Oct 20, 2009 | Breville SK500XL Stainless Steel Cordless...
My ice taste like plastic
if there is a filter change it or use more of the water so it does not sit too long and get stale
Aug 03, 2009 | GE GSS20IEP Side by Side Refrigerator
Terrible taste that came from water?...
Do you have a water softener? It's possible the softener was in soak when you used the water dispenser. That would explain the "salty" (hi sodium) water taste and thena retrun to normal later.
Also, if you get your water from a muncipal well, they may have been experiencing a problem at the time with higher than normal sodium content.
Apr 08, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Coffee tastes like metal
THIS HAS NOTHING TO DO WITH THE COFFEE. This has to do with water filter system and most importantly descaling of machine, as over time the metals in side machine and tubing get a mold type build up. Its a chemical reaction from the water and tubing and the coffee and metals. To 100% solve this, descale the machine with water and vinegar mixed. Do this a couple of times and use bottled water to fill water tank if you do not have a good water filter tap system. I have been the espresso business for over 16 years with 4 locations, and it has nothing to do with the coffee. If it was the coffee or poor coffee it would tasted burned or bitter, but NOT tasting like metal.
Please rate my solution as you see helpful, Thanks Mike Espresso Expert
Jul 02, 2008 | Dacor CM24P-1 Coffee Maker
Magic mill hot water urn, 7.0 Qt
I replaced the cover once. With the second cover, I found if I put a teflon glove on the back left, the pump worked properly.
Mar 26, 2008 | Magic Mill 8.5Qt. Electric Hot Water Pot -...
Kitchen Appliances - Others Logo
458 people viewed this question
Top Le Chef Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Le Chef Kitchen Appliances - Other Expert? Answer questions, earn points and help others
