Question about Olevia LT37HV 37 in. HD-Ready LCD Television
A line, red, vertical line extends from the top to the bottom
A line, red, vertical line has appeared on the tv that extends from the top to bottom of the picture.
    President:
  • 1,961 Answers
You must reset the system of you TV.Open the back cover of your TV reach for the main board.there is a small button on the main board just press it and the error of your TV will be ok...
please rate me..
Posted on Jun 06, 2010
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
No image, Just red and blue vertical line on display.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
Thin red line appears on screen. Purchased Nov. 2007
the minute parts near the picture tube might have misaligned ,,,,,, you need to align those parts .... contact a good tv mechanic .... he will use a magnetic type material and align every minute parts correctly near the picture tube, the red line wont appear again
Mar 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Olevia LT37HV 37 in. HD-Ready LCD Television Logo
370 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
