Question about Goodman GMS90703BXA Heater
Gas dose not come on
And there is a red blinking light on the mother board. Goodman forced air heater.
  • 674 Answers
The blinking light is giving you a trouble code for the unit. It should have a label or something inside the unit or in your owners manual to let you know what the code means. Count the number of blinks. It should repeat over and over.
Posted on Jun 06, 2010
Testimonial: "Thank you so much, lightspeedsq."
We have a Goodman heater and when we turn it on, we can hear the heater start up, but no hot air blows. There is a red light that is blinking 3 times.
The blinking red light is a diagnostic LED that will help narrow the problem to specific area. You need to find the legend for this. It should be posted on the equipment somewhere in the form of a sticker, either on the doors ( check both sides ) or on the electronic control board housing. You can also look in the literature if you have it. Once you have this info it will let you know what the general reason is for not functioning properly. It may need the attention of an Hvac expert.
Feb 03, 2011 | Heating & Cooling
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
Gas will not come on goodman gmnte 120
The exhaust motor starts first andthen closes a small air switch (pressure switch)...if blocked pipe or tube to switch unit will not fire. You can also look at the light on the circuit board for blinks...this will tell you what is wrong. Read bottom blower door for fault codes
May 09, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model#GCH90904CXAB the red light
This model is equiped with a diagnostic error control. Take off the front panels and look for a wiring diagram pasted on the reverse side of the panels. On this diagram there will be a chart telling you what 4 blinks represent and where to start looking for the issue. I suspect the air filter may be dirty or the pressure switch may be bad, however make sure the condensate hoses are free of any debris. Good luck to you!
Apr 25, 2010 | Goodman Heating & Cooling
Circuit board light blinks 3 times heater will not turn on
The error code refers to a defective combustion air switch. Coleman Evcons made around 2007 had defective pressure switches or as they call them "combustion air switch". Replace it and the problem is gone.
Dec 13, 2008 | Goodman GMS90703BXA Heater
My Goodman Heater the red light keeps flashing steadily ,I put new mother board on it anit is still doing it. something twinnig wires , whats does tht mean
Just reverse the power wires and the ground wire going to the unit (black / white wire going to the unit. or just reverse the power wires (black white wires going to the thermostat.. t y v much!
Dec 10, 2008 | Heating & Cooling
Janitrol gmp125-4, blower shuts off while burners still on,
Sounds like fan motor is bad getting hot and opening the circuit inside the motor and then after couple minutes cools off enough to complete the circuit and runs for little while and does it over and over.
Nov 23, 2008 | Goodman CLJ30AR32 Air Conditioner
AIR or Heat wont come on/ goodman GMP075-3
If there is no blinking light, then the unit is not seeing a call for heat or cool. My guess is a lose or broken wire in the thermostat circuit. Try and putting a jumper across the red and white heat terminals inside the furnace and manually closing the door switch. If you get heat, it's telling you there is a wiring issue. If you get nothing, it's a bad circuit board.
Jun 08, 2008 | Goodman GMS90703BXA Heater
Goodman Furnace m/n GKS90453BKAC
A constant red light (not blinking) indicates that the thermostat is not calling for heat. Of course you know it is but just to be safe, jump out R and W on the board. If it continues to do the same as you indicated, replace the board.
Dec 05, 2007 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
755 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
