Do i need a special tool to install the wire and spring that goes around the rubber seal between the door and drum?
    President:
  • 1,554 Answers
It is not necessarily needed to have that spring removal tool to remove or install the wire and spring assembly. Instead, use two pairs of needle-nose pliers to grasp each end of the spring and stretch it apart.
Posted on Jun 06, 2010
HOW TO REMOVE RUBBER SEAL
ok if you look around the front of the rubber seal you will see a wire holding it in place on the wire there is a spring if you pull the spring off with a pair of pliers the door seal will just pull off the cabinet then take off the lid and you will see the wire that goes around the door seal where its held onto the drum some have a screw on it and some just pull off then give the seal a good pull from the front of the machine it will pull off quite easy then just push the new seal into place and replace the wire thankyou
Jan 23, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
When moving a whirlpool washing machine (Model AWM 1000) a large thin metal ring (spring-loaded at one end) came out. Where does it go to refit it and how do I refit it? On the machine there's a groove...
It goes to the outer lip of the door opening where the groove is to secure the door gasket. It definitely serve such purpose, not for nothing.
Oct 13, 2010 | Washing Machines
Washer leaks during spin cycle. my daughter pulled the drum out of alignment temporarily while pulling a comforter out of the washer. the door seal is intact although there is a wire ring that came out...
The spring goes around the door seal it needs to be stretched around the small lip that holds the seal in place. The spring is where you grab it with needle nose pliers. the spring goes on the bottom. You will see where the rubber seal has a wider spot this is where the spring should be right at the 6 o'clock position. This is a little tricky to do the first time trying but keep at it you will get it.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to remove door rubber to clean around drum
on most machines there is a spring/cable that goes all the way around the seal. easy to get off but requires a special tool to get back on... would advise having a tech do it.
Oct 24, 2009 | Washing Machines
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
I do not know how to install the new seal I ordered for my front loader it is a large rubber circular piece. help
There are two large spring clips that hold the seal in place.
If you open the door and feel around the outer edge of the seal you will feel a metal wire that is held together by a short spring. You need to expand this spring to enlarge the wire circle (not too much as you can cause damage to the spring itself). Most techs use 2 vice grip needle nose pliers to do this. Once the spring clip is off you will need to fold the seal inward. Around the base of the seal where it meets the tub there is another wire spring clip assembly. You will need to remove this one as well. If there is a drain port on the seal you will need to un-clamp this one as well
The new seal goes on just like the old one came off. you will need to expand the spring to clamp the base of the seal around the tub. and again with the uoter seal lip around the opening of the door panel.
This procedure can be quite tricky and LG does have a special set of pliers for this job. It can be done without the special tool but it require quite a bit of patience and strength.
Aug 05, 2008 | LG Washing Machines
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Door seal wire spring replacement
oh my there is no way but to take front off and you need special tool to hold the spring in place this may a job for a tech IT IS NOT FUN!!!! but there is NO WAY to put spring back on Trust me Ive tried Good luck
Dec 17, 2007 | Frigidaire GLTF1040A Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
