Question about GE GSS25SGSSS Stainless Steel Side by Side Refrigerator
GE Water not working
Hi, I found your comments on this forum and we are lazy too and didn't change our water filter for a few years until it stopped working. Have since changed the filter but not getting any water out the door. Did you ever get yours to work? If so, how?
Thanks,
Matt
You may have a frozen water dispenser tube inside the freezer door. You need a GE Water Dispenser Tube Heater Kit, part number WR49X10173.
Posted on May 12, 2008
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Can't unscrew water filter canister from main water system, I tried silicone spray didn't work.
1. Turn the incoming water off.
2. Open closest cold water faucet, let it run until no water.
3. Turn off outlet valve after filter.
4. Hold down red pressure relief button, until no water.
5. Unscrew filter bowl with filter bowl wrench (if you have one).
If this does not work repeat steps 1-5 and turn the water off at well tank or water meter. Never tighten pre-filter with wrench, changethe o-ring every year and lubricate the o-ring every time filter is changed.
RJ
Sep 22, 2011 | Culligan Sediment Water Filter
Changed water filter, and now no filtered water comes out. Water had slowed, and it stopped making ice, so replaced the filter like always, and now no filtered water comes out at all Bought the same...
Don't know which filter you use, so this might not work. Try reversing the filter to see if it got installed incorrectly.
If not, make sure the the water line didn't get kinked and that the valve is open.
Jun 08, 2011 | Kenmore Refrigerators
GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
May 06, 2010 | General Electric GE SmartWater Household...
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Getting light to turn off after changing water filter
Press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks
Jul 30, 2008 | Jenn-Air JSD2789GES Side by Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
GE GSS25SGSSS Stainless Steel Side by Side Refrigerator Logo
138 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
