Question about Sony Playstation 3 (PS3) Console
I replaced the disc drive, hard drive and the fan and it still wont read video...I put the disc in, it takes the disc and then it sounds like it stops. The blue light in front just stays continuously on...also the fan seems like it is not spinning. What could all this mean?
  • 115 Answers
Your game console is probibly stuffed up so you will have to get it reapried because there isn't much you can do or maybe the game is wrecked try all your games good luck:) and please rate this solution...
Posted on Jun 06, 2010
Wii wont read disks
Well it sounds like the disc drive and the laser that reads the discs is either weak or has gone bad then so so it will need to be replaced then. If the discs look fine then it's the disc drive gone bad
Oct 09, 2012 | Nintendo Wii Console
Ps3 wont read any disk I replaced the drive and still wont work, what could be wrong
to solve this problem, you need to take out the hard drive. the ps3 hard dirve can be hot after you play games for a while. the DVD ROM probably won't function when the hard drive is over heated. the hard drive should be put in cool place. you should let the hard drive remain in a cool spot temporarily. the place where you put the hard drive should not be exposed in direct sunlight. you can open window and let the air come in while playing. you can switch on the fan and turn it against the hard drive. in this way, the heat in the hard drive will quickly dissipate away.
sometimes, the DVD ROM is not functioning properly because of loose cables. checked the cables to see if they plugged in properly. you can plug out the cables and replug them. after replugging them, you can turn on your console to see if it's working again. just make sure that the disc tray isn't overly dirty or filled with dust, this can cause the reader to not work. always wipe the disc tray and the disc that you're using before playing.
if this didn't work, you have to send it to sony. you have to pay delivery cost and repair cost. if it's still under warranty, you only have to pay the delivery cost.
Dec 02, 2011 | Sony Playstation 3 (PS3) Console
It seems the xbox 360 wont read the disc... every time i go to play a game alls it says is open tray... and the game never loads..
I have had the same issue and it turned out to be my hard drive. If you take the hard drive off the xbox, it will read the disk right? Then replace hard drive and the problem comes back? I stopped using the hard drive and I now use the little save cards that go into the front of the xbox. hope this helps.
Oct 22, 2010 | Microsoft Xbox 360 Console
The playstation 3 wont read discs. Regardless of what disc I put in, DVD, Bluray, game or CD it just wont read. I'm pretty sure that it's not spinning the disc because it doesn't make the humming sound it...
You could buy a new Bluray drive and swap the dead one out. They cost around $80 and aren't hard at all to swap out. You could also try to lubricate the shaft of the drive motor, as it may just have ground to a halt from friction. Other than that, there's not much other than getting a repair/replacement from Sony.
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
I put the disc in and on my tv it says open tray and when I do that and close it it says reading then goes back to open tray.
Hi friend try this:
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
if the problem still persists then you need to replace your disc drive.
Please vote for me.
Feb 09, 2010 | Microsoft Xbox 360 Console
My xbox wont read discs, when i put the disc and close the tray, it says its reading the disc and then just says "open tray" as if not even reading the disc at all
take a can of air and gently blow some into the drive. If that doesnt fix it then at that point its going to be either a problem with the laser in the drive or you can replace the dvd drive itself. Either way you go, try Ebay cause you can usually find parts for the 360 cheaper then most places.
Nov 28, 2009 | Microsoft Xbox 360 Console
Not detecting any discs Blu ray discs
It sounds to me like your BLuRay drive or your Drive Sensor has crapped out.... I would take this to a local video game repair shop.
Is it still under warranty ?
If not I have seen both these parts on ebay...
Drive with sensor is $65 shipped and sensor alone is $25 shipped... hope this helps.
Jul 28, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Wont read blu ray discs
its because your lens kit are defect search on google for replacement lens ist about 80$ usd its not really hard to replace but verify that your warranty is over before lol
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 wont read disc
Though i fixed the Disc Read Error myself within an hour but please test the below method at your OWN Risk. Please also note that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourself within an hour. It also provides the money back guarantee in case you are not satisfied. As i fixed my Xbox myself so i thought to share it with you guys.
Jan 25, 2009 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
