Question about Apple Power book G4 Refurbished Notebook - PowerPC G4 1.6GHz, 1GB DDR, 100GB HDD, DVDRW, 15.2&
I-book G4 Lap top got wet from the rain but just on the outside , it was closed, high humidity today, all of a sudden my mouse is acting strange as well as the keyboard. Pushing buttons that do something else and not what they are supposed to do? Any suggestions
  • 115 Answers
That happened to my laptop the one im using right now it only got a bit of water inside the key-board and when i turned it off and turned it back on it acted strange the wierd colours came i didn't really too much and like after a couple days it stopped just wait for the water to like dry if it doesn't stop then take it to someone that repairs laptops and try not to get ripped off they do that alot so goodluck:) and please rate this solution... cya
Posted on Jun 06, 2010
How do I connect mouse to laptop
Look along the outside edge of laptop until you find the correct port to fit mouse cable, that said lap tops usually have a flat area below key board that will act as a mouse would when you slide a finger across it
Oct 05, 2015 | Computers & Internet
2003 chevy 4.3v6 won't start when wet out
Did you change the plug wires when you changed dist. cap and rotor?? If not and you want to be sure they are the prob, wait till it's sunny outside and the truck works fine, then get a spray bottle (like an empty windex bottle or something) and put some salty water in it and spray the wires with it when the truck is running. If the engines starts to act up, sputter and what not, the wires are done for, throw em and change em. Also if it's dark enough you will usually easily see the sparks flying around the wires and all when you spray them. Coil isolation might also be the problem, but it's alot rarer than the wires. Same test procedure can be easily done here also. If both those test out good with the salty water, then it's going to be harder to pinpoint, but at least the good ol' salty water trick will work with anything related to humidity/rain and will help you size down the possible problems and areas that can be in fault.
Dec 31, 2013 | 2003 Chevrolet Silverado 1500
Acceleration
A dirty air filter will be worse when damp.
Nov 27, 2013 | Subaru 2007 Outback 2.5I Limited A/C...
My 2003 toyota camry on the driver side front floor matt, the carpet is wet. It is wet even though we have had no rain. and is hot.
Could be the A/C drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the cab. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Also, its been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the cab. The drain may not be able to handle a large, sudden quantity of water.
Perform a "driveway" test. Open the hood, start engine and run the A/C on normal with the windows or doors open. Locate the drain tube by looking for water dripping. Once located twist 2 or 3 pipe cleaners together and verify the tube is clean.
Aug 03, 2011 | Toyota Camry Cars & Trucks
Fujitsu AST12LSBCW flashing timer light no cooling
There can be two things that causes it not to cool right in humid weather..........dirty unit or low refrigerant. Clean the inside parts and the outside parts thoroughly and then try again. If it still doesn't cool or gets worse, then you know the unit is low on refrigerant.
Apr 02, 2009 | Fujitsu Heating & Cooling
Astro vans that won't start if it's damp/raining outside
I have a 2000 Astro had the same troubles.I saw that the sides of the coil were burned looking.In between the bar that goes around it. This started around 110K It would run badly when wet or high humidity.Then throw up the check engine lite.Put on a new coil so far the problem has no reocured.
Feb 03, 2009 | 2000 Chevrolet Astro
Erratic starting problems
i just had the same problem i thought it was weather related ,too but it was not. you need to replace the ignition module mounted beside the coil and its set in an alumine bracket that has wires that plug into it it cost about $ 72.00 very easy to replace
Dec 24, 2008 | 1998 GMC Jimmy
Wont start when humid or rains
maybe or somthing as simple as a crack in the dist cap
Jun 20, 2008 | 1998 Honda Accord
Canoscan LIDE 30 - mac lap top
Download the installer here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=119&modelid=6623#DownloadDetailAct
Jan 16, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Apple Power book G4 Refurbished Notebook - PowerPC G4  1.6GHz, 1GB DDR, 100GB HDD, DVDRW, 15.2&  Logo
63 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
