Question about Dryers
Dryer is noy heating up everything else seems to be working seems to be getting 240 volts
  • Anonymous Feb 27, 2009
    I checked all three and they are fine. What next.?
  • 5,911 Answers
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back if you have any further questions and/or need assistance locating parts. A make and model number would be helpful.
Posted on Apr 10, 2008
Heaqt willnot work
The list of suspects usually invovles the heating element, the limit mounted on the heating element, the circuit breaker. The motor is a 120 volt one but the heater needs 240 volts. If the breaker is partially tripped the dryer could run but havee no heat. If the dryer cord id partially out of the recepticle the heat will not work. Make sure the dryer is getting 240 volts. Videos and more are here on my page
Mar 06, 2012 | Whirlpool Dryers
I have a Samsung DV210AE Dryer that is 3 weeks old, everything works on the dryer except no heat and it is not showing any codes what do I need to do. Thanks!
The first thing to check is if you have 240 Volts going into the dryer. The display, lights, and motor run on 120 Volt but you need 240 V for the element.
May 20, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
My dryer was working fine but now there is no heat?
Check to make sure that your 240 volt breaker to the dryer hasnt tripped. the dryer drum only needs 120 volts to tumble, but the heating element needs 240 volts to heat up. Or the element itself has quit, or the tstat controlling the element has burned out
Apr 27, 2010 | Dryers
Ariston AS66VXNA dryer - everything works but no heat- looking for a schematic to check out and troubleshoot - where can I get detailed schematic?
You can find a manual for your model here>>>>>>>>> http://laundry.manualsonline.com/manuals/mfg/ariston/asl70c_1.html Let me ad that you may have just one side of the 240 volt circuit breaker or fuse set tripped or blown allowing all of the electronic functions, but not allowing the full 240 volts across the heating element. One way is to check the fuse box first and then proceed to measure voltage across the heating element after turning on the dryer. Please use caution while doing this. Ariston Clothes Dryer User Manual ManualsOnline com
Jan 17, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
Dryer will not heat. I have 240 volts at the
Even though you may have 240 volts at the element, have you checked the element itself? Turn off the power, disconnect one of the leads (both would be better) to the element, set your meter to ohms x 1000, place the leads across the element terminals and see if the element has continuity. It could be open.
Dec 18, 2009 | Office Equipment & Supplies
How do you check voltage to dryer?
The first thing you should check on a electric dryer when it does not heat or run is the voltage at the cord.
If you do not have the correct voltage your dryer will not heat and may not even start.
The dryer needs 240 volts for the heater to work. It gets 240 volts by using two 120 volt lines. If one of these 120 volt lines is dead it will not heat. It may or may not still run as the dryer only needs 120 volts for the motor to run.
If you have one 120 volt line missing power and it is the same 120 volt line that runs to the motor then the dryer will not run or heat.
May 30, 2009 | Dryers
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore gas/electric dryer
theordis:
When you say electrical power is working Ok ,I would assume you are saying this because the dryer is tumbling.
Which could mean you are only getting 120 volts to the unit but it will not heat with out 240 volts.
If you are getting 240 volts.
You could have an open thermostat, an open heating element. A bad timer contact or a open switch on the motor.
All these can be tested with a Volt-Ohm meter.
((((The Electrical supply must be turned off and at least one wire dissonnected from the component being tested.
woodychoppers
Aug 13, 2008 | Kenmore 75944 Gas Dryer
Dryer works when turned on but I am getting no heat
hi thanks for the question it could be the heater or a hi limit thermostat located at the top left of the heater housing make sure you have 240 volts at dryer thanks the appliance doc
Aug 04, 2008 | Kenmore 62872 Electric Dryer
Ler662
CHECK FOR 240 VOLTS AT DRYER ELEMENT WITH DRYER
RUNNING IN HEAT CYCLE. IF NO VOLTAGE, CHECK WALL
OUTLET FOR 240 VOLTS BETWEEN LEFT AND RIGHT SLOTS IN RECEPTACLE. A DRYER WILL RUN ON 120 VOLTS TO
GROUND BUT WILL NOT HEAT IF 240 VOLTS IS NOT PRESENT. IF THERE IS 240 AT THE OUTLET, START TRACING THROUGH THE HEATER CIRCUIT. LOOK FOR A FAILED THERMOSTAT OR THERMAL FUSE NEAR THE HEATER OR EXHAUST OUTLET. CHECK THEM WITH A CONTINUITY TEST WITH DRYER UNPLUGGED, OR A VOLTAGE CHECK WITH A HOT CIRCUIT.
Jul 28, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
169 people viewed this question
Top Dryers Experts
