Question about Epson Stylus CX4600 All-In-One InkJet Printer
Ink not present when printing
I have just recently installed/replaced the black ink cartridge and now the paper is coming out blank! Any suggestions?
  • Anonymous Jun 08, 2008
    error
    error light blinks and print comes out blank.
  • 35 Answers
If the printer went through a period of disuse, I recommend you read my solution the thread at http://www.fixya.com/support/t743789-printer_will_not_print_even_though
Posted on Aug 13, 2008
  • Jefferson Casavant
    Jefferson Casavant Aug 14, 2008
    I am going to copy the instructions into this thread for your convenience.
    The ink heads are clogged with dried ink.
    Follow these steps:
    1) Begin saving money for a new printer.
    2) Lift the scanner to get at the ink. Remove the cartridges.
    Take cotton swabs and alcohol and clean all the ink off of the top of the heads (located in back. they're the pointy things) until you can see the holes. THE CRUCIAL STEP: Insert something-small enough to fit in the holes-all the way through every hole in every head. This should clean out the dried ink and allow your printer to continue to work.
    3) If step two doesn't work, I really hope you did step one.
    Don't buy an Epson. They also have this other feature which prevents printing when one cartridge is empty. Even a color cartridge. I recommend a Canon, if you like name brands, or an HP.
    To Clean the Main Print Head
    Remove the ink cartridges.
    There are two screws on the gray ink lid, visible when open. Unscrew them, and then remove the lid. There are three screws inside the ink carrier. Remove them.
    Get a pair of Needlnose Pliers and a flat-head screwdriver.
    There is a plastic plate near the front of the ink carrier, at the base. It forms a right angle with the left side. On the top of the left side portion of this plate, insert the flat-head screwdriver and lever the plate inwards. It will come off to reveal two gray cables. Take the needlenose and grasp one of the ink heads. Pull upwards and towards yourself. When you can, remove the two cables from the ports in a straight outwards direction. This should free the main print head from the rest of the printer.
    At this point, you can purchase a new main ink head or wash your old one. I am cheap and chose to wash the old one.
    Get a small tub and some rubbing alcohol. Pour the alcohol into the tub, and immerse the print head for several hours, shaking every once in a while.
    Now comes the long cycle of cleansing the head totally. Have a rag ready. Remove the head from the alcohol, and wipe off the smaller print heads (the points). Then, (here comes the crazy part) put it up to your mouth and put as much pressure as you can into all four, for about ten seconds. Turn the head over and wipe off the ink that has come out. Repeat until no more ink comes out. Then, immerse the head again, remove, and allow to dry naturally (or possibly by blowing on it). Make sure the two ports for the cables are dry.
    Reassembling the printer/Inserting a new or refurbished head
    Before pressing the head back into place, connect the cables, right one first. There is an indentation on the top side of the head for the cables to fit. Then, place the head snug into the ink carrier, front side first, angling towards the back, until it is flat. Reinsert the plastic plate. There is a small tab on the right side of it, and that goes into the slot near the end of the right cable. Press the plate back into place gradually moving towards the left, starting from the tab. Put back all three screws, two on the top and one on the middle right. Reattach the cover, with the two screws on the left and right. Reinsert the cartridges, and you should have a working printer.
How do I fix my printer it prints blank sheets it acts like its printing but the paper is still blank I did nozzle and print head checks nothing still blank
I hate to state the obvious, but how long has it been since you've changed the ink cartridges on the printer. If you have done both the nozzle cleaning and print head alignment and nothing appeared on the paper, I don't know what else it could be.
This following suggestion is very rare - if you recently replaced the cartridges and your printer hasn't printed since then, it is possible that you installed them incorrectly; OR perhaps you left the head protector tape on the cartridge. But then it wouldn't "see" the cartridge.
In the "rare" situations, you should try to remove and replace the cartridges to assure that they are properly installed.
Mar 05, 2015 | Epson Stylus CX6600 All-In-One InkJet...
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
My F4180 has stopped printing with the black cartridge. I have checked with different cartridges and have also uninstalled the HP software fully and then made a new installation with all new driver. No...
It's like the ink is not flowing at the nuzzle! To check this you take some tissue paper, fold it so that is is a little padded. Press the black ink cartridge nuzzle (this is the bottom part where the ink comes from) on it. If black in is flowing well, the tissue ahould come out blotted with black ink. If it does not, it means either the ink is blocked or the is finished. Try this with every black ink cartridge you want to test.
If see the blot of black and the problem persists, clean the "electronic" contact side of the cartridge with tissue soaked in a bit of methylated spirit. Do the same to the area it makes contact with inside the printer.
Then try to print.
Sep 20, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Printing but blank pages coming out .
Take the ink cartridge out of the printer. On the bottom of the cartridge, there's a copper/gold surface with bumps and holes. Take a napkin or peice of paper and rub it on this surface. This serves two purposes - if there's any dried ink or blockage, it will help clean it, and it's a test to see if there's any ink left in the cartridge. On a normal ink cartridge, rubbing paper on the bottom would cause some ink to smear onto the paper. If nothing wet comes out, the ink cartridge is dried out or empty. You'll need to replace it.
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Blank paper comes out
Please clean the print head for 3 to 6 times and after each cleaning print a nozzle pattern to verify if the cleaning is successful or not. After 3 to 6 cleanings and issue still present, reinstall ink cartridge. By doing all those steps and issue still present - the print head is clogged badly by dried inks or contaminants. If your printer is under warranty - I suggest call your printer's manufacturer and ask for replacement if not decide whether sending it to service center is cost effective or buying new printers.
Oct 02, 2008 | Epson Stylus CX6000 All-In-One InkJet...
My HP Photosmart C6180 All in One printer is not printing ing black even though I have replaced the black ink. It will print the colour sections but comes out blank for black. Any suggestions as to what...
Remove the black cartridge from the all-in-one and clean the copper contacts of the cartridge with a soft cotton cloth and then try to align the cartridges once and then try to print the self-test page. Also check the ink level and expiry date present on the cartridge.
May 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Epson Stylus CX4600 All-In-One InkJet Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
