Question about Frigidaire FEQ1442ES Electric Dryer
How to change 3 plug to a 4 plug cord - Frigidaire FEQ1442ES Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote that will help you to wire your 3 prong plug to a 4 prong...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Posted on Jun 06, 2010
How do you change a 3 prong cord to 4 prong power cord on a maytag neptunre MDE4000ayw
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How do you connect the LG DLEX5101V Dryer to the electrical outlet on the wall if there is no cord to plug in?
There are a couple of types of plugs in homes - and the dryer manufacturer use this excuse to not ship a cord with the dryer - profiting that much more. You'll need to purchase a cord set for your dryer. Assuming you live in the U.S., that means you need a 30 amp 240 volt cord. That's easy enough, but it does get harder.
Most homes have an outlet that has three slots in it - like the one below:
A 240 volt, 30 amp, 3 wire dryer plug.
New homes have a safer, 240 volt 30amp 4 wire plug. They look like the one below:
A 240 volt, 30 amp, 4 wire dryer plug.
The code states that when a dryer is purchased it should be connected via a 4 wire cord. This means if you have the older, 3 wire outlet - it will have to be changed along with the entire length of cable between the electrical panel and the outlet (the new outlet needs a 4 wire cable - the older plug was supplied by a 3 wire cable).
Those are the rules. Many people opt to purchase the older 3 wire cords so that they can connect directly to the 3 wire outlet already installed in their home. As an electrician, I have to caution you on doing that. It is a violation of the electrical code as it has been identified as an unsafe condition. The code hopes to rectify this by slowly requiring new dryers to be wired with 4 wire cords and making the homeowner upgrade the old 3 wire outlet to a newer, safer 4 wire outlet. Of course, no one will come to see what you had and if you changed it, etc.
Mose hardware stores, Home Depot, Lowes, etc. sell these cords for under $20. Make sure you choose a 30 amp dryer cord - and not the similar looking but thicker 50 amp stove or range cord.
I hope this helps & good luck! Please rate my reply.
Mar 22, 2011 | LG Dryers
Change 3 prong cord to 4 prong cord on electric dryer
heatman101
Feb 16, 2011 | Maytag Dryers
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
The cord need to be changed from a 4 prong cord, 4 wire to a 3 prong cord, 3 wire 220V. which of the connections do i connect to?
heatman101
Sep 15, 2010 | Kenmore Dryers
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 | Dryers
Change out 3 cord plug with a 4 cord plug
very easy just put the white to the middle the black to the left the red to the right and the green can attach to the cabinet with any screw close by
May 11, 2009 | Dryers
Frigidaire FEQ1442ES Electric Dryer Logo
130 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
