Question about Kirby Ultimate G Bagged Upright Vacuum
My kirby will not turn on - Kirby Ultimate G Bagged Upright Vacuum
    Problem Solver:
  • 5 Answers
YOU NEED TO CHECK THE WIRE, SAFETY SWITCHES & POWER SWITCH, ONE OF THEM HAVE PROBLEM
Posted on Aug 23, 2010
Tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
on Mar 21, 2010 | Kirby Generation 3 Bagged Upright Vacuum
How do i replace the on and off switch on a gen 3 kirby sweeper
fault will be cable not power switch, phone your local kirby enginere for fixing
Jul 31, 2012 | Kirby Ultimate G Bagged Upright Vacuum
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
KIRBY ISSUES! :(
sounds about right you should change that type of belt every six months to a year regardless if its broken or not. one other thing you should do is make sure the brush roll itself isn't bound up it should spin freely if not you can pull the plastic ends off the roller to clean any hair or thread out .
Sep 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5
See my troubleshooting guide and from there, you can view my do it yourself guides for fixing your Kirby.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Aug 26, 2008 | Kirby G5 Bagged Upright Vacuum
I can't get the new belt on my kirby
I can't get the new belt on my Kirby
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The Kirby Vacuum has a removable head and bottom plate and the belt is hooked on by a hook inside of the Kirby head of the vacuum. You need to slide the belt onto the Kirby brushroll to the center and the dial in front of the Kirby vacuum does rotate to the right – so @ this time you would dial the belt clockwise and the inside hook will pickup the inside belt and continue turning the dial / hook until it stops – look inside to see if the belt in on the fan shaft – if it is then install the bottom plate back on the vacuum and then install the head back on the Kirby or if it is newer the head is already on the motor assm.
Plug in the vacuum and if the belt stays on and the brushroll is tuning you have done it right – if not reverse the situation, unplug the vacuum and start over with the procedure. The hook will dial the belt onto the fan pulley if done correctly. Example: try to turn the dial on the front of the vacuum to see hoe it works and the way the dial will turn so that the procedure will be easier. The dial does turn hard when dialing the belt onto the pulley.
http://kirby.com Contact Us by Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Apr 16, 2008 | Vacuums
Engaging belt on Kirby G5
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. The hook stretches the belt so that it can fit over the fan drive.
Next, place the two "feet" of the powerhead onto the "perch" on the front of the kirby....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
then turn the belt lever from off to on.
the G5 should have a light on the powerhead that comes on (green) if the belt is spinning the brushes. That will let you know if you've got it on correctly.
Dec 24, 2007 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
52 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
