Question about Maytag HYE3658AY Electric Dryer
Maytag Dryer mdl #hye3657ayw won't turn and has a burnt smell
When I run my dryer, it isn't turning and it has a burnt smell like it's overheating. What are my options to fix this. Thank you.
  • 94 Answers
SOURCE: maytag dryer
Your door switch might be defective and/or your timer might be defective. If it has a fuse inside it might be blown.
Posted on Oct 07, 2007
SOURCE: maytag dryer PYE3300AYW Continuously runs
I have same problem. Timer advances, but doesn't stop at the proper settings.?
Posted on May 14, 2008
SOURCE: Maytag dryer does not maintain heat and clothes smell
Save yourself the repair call and replace the gas coils. They're a $30 part and it takes all of five minutes. Works like a charm.
Posted on Oct 08, 2008
abhishek33
  • 1239 Answers
SOURCE: Dryer won't turn off
hi please rate the last solution atleast as thanks for trying.
Posted on Dec 31, 2008
SOURCE: Maytag dryer model HYE3657AYW
I assume that your u.s. dryer is the standard 220 volt, and your question is what is the voltage in Mexico where your father resides. Most places in Mexico will have the 220 volt supply available. This should be easily found out with any cheap 15.00 meter. If the receptacle accepts the dryers plug, it is more than likely the proper voltage.
( Maybe your father is really wanting to save energy and realizes that his clothes will last forever when they are hung up to dry! )
Posted on Mar 05, 2009
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
Sep 03, 2012 | Maytag Dryers
Maytag dryer hye3657ayw does not run. When I open the door the light doesn't come on but there is power at the outlet.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 07, 2011 | Maytag Dryers
My dryer stopped running in mid cycle and there was a burning smell. I thought it may be the belt, but it is not the belt. Also, the light inside the dryer hasn't worked for years, so I don't think...
heatman101
Jun 15, 2011 | Maytag HYE3658AY Electric Dryer
Have a Maytag electric dryer, model # HYE3657AYW, stopped working all of the sudden. doesn't do anything when I set the timer and push to activate. I checked the voltage at the plug, and at the back of the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 07, 2010 | Maytag Dryers
Maytag stackable dryer will not run. When the start button was pressed, there was a sound of the motor trying to turn, but there was not turning. When pressed repeatedly, there is a burnt smell
heatman101
Aug 23, 2010 | Maytag Dryers
The dryer wotn work; it makes a noise and it smells like burnt
heatman101
fgfg
Jan 19, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
We moved the dryer in and turned it on. There was
Sounds like the motor shorted. Pull it apart and look for burnt wires and/or a burnt motor. The motor itself will smell burnt if it is.
Dec 13, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Mar 04, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag HYE3658AY Electric Dryer Logo
239 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
