Question about Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB
Amana AFD2535DEB with french doors was working well. Then the bottom stopped freezing things. It was as if it just defrosted itself. Any reason for this?
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Posted on Mar 12, 2008
  • 20 Answers
SOURCE: amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
Posted on Jun 04, 2009
heatman101
  • 43501 Answers
SOURCE: Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Jun 06, 2011 | Amana AFI2538A Bottom Freezer French Door...
Amana bottom freezer problem
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Installing upvc french doors and frame
you only want 1/8 th inch all the way around the door make sure to level hinged sides and shim them in make sure to constantley look by opening and closeing door that you have 1/8th all the way around
Oct 05, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Aug 07, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
We have upvc french doors, 1 seems 2 have dropped and is catching at the bottom is there any simple way to adjust this?
yes if you have an hinge which looks like small flag there are 3 ajustment places on these you need the one pointing towards glass on tip of flag normally small white cap on front take off and use allen key and it wind back towards wall taking off the drop to it if not flag hinge you will have to call engineer ok hope this helps bub
Jun 29, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Amana model BR18VW Freezer on the bottom..
couple things to check BEFORE calling the technician.. Check to make sure the coils under it are clean,  2nd make sure the coil cooling fan is working.. you can do this by getting behind the machine and check to see if the fan there is blowing..
IT could also be the defrost timer or the defrost heater.. these work in the back ground so you will never know unless you have ice buid up and such..
Hope this helps
May 30, 2008 | Amana AFD2535FE Bottom Freezer French Door...
Mar 12, 2008 | Amana AFD2535DES French Door Refrigerator
Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Logo
77 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
