Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Handle is loose on refrigerator,how to tighten the handle
Handle is loose on fridge door
  • 973 Answers
There should be some small Allen (Hex) screws on each bottom side of the handle. Just use a Allen wrench and tighten it up.
Posted on Jun 06, 2010
  • never2old Mar 10, 2011
    we have a kenmore elite refrigerator model# 59676253701 with the freezer on the bottom. I have tighten the freezer handle 3 times now. I'm thinking about using lock-tight on the screws.
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
How to tighten a loose door handle for On the fridge upper half?
Gain access to inside of refrigerator door to refasten the loose handle.
Mar 06, 2016 | Bosch B36IT71SNS (20 cu ft) Bottom Freezer...
We have a 3 month old fridge and the handle is coming away from the fridge. There is a bolt under the handle which suits a 4mm allen key, but it does not seem to do anything if you tighten or loosten it. ...
The bolt on the handle tightens on a pin that comes through the door. If the tightening the screw on the handle and it still does not tighten then the pin has come loose inside the door. If the unit is only 3 months old I suggest contacting who you bought it from. It should be under warranty.
Feb 03, 2015 | Refrigerators
Door handle came loose .how do i tighten it up`
hello kyler.... Empty out the contents of the door of the fridge. Then pull up the gasket and under that you will see screws. Remove those screws and the entire inside of the door is released exposing the screws to tighten the handle. Joe
Thanks for choosing Fixya!
Feb 24, 2011 | Whirlpool Refrigerators
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Oct 29, 2007 | GE GSH22JFR Side by Side Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
698 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
