Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Soap dispenser does not empty
Machine cycles but no soap is used.dishes come out dirty
  • 523 Answers
Make sure the water is hot/prime sink before turning the dw on
Posted on Jun 06, 2010
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Soap dispenser not emptying during cycle. Dishes
Checkout this tip that I wrote about that problem...
Dishwasher Repair Problem Detergent Cup does not Open
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jul 18, 2010 | Maytag Dishwashers
Soap doesn't empty from dispenser
Assuming you are using the correct detergent powder, check if the dishes are remaining dirty.
The water from the impeller may not be rushing up enough due to blockage or limited movement of impeller arm. Follow the insructions to clean the impeller, filter etc or check base of drawer for obstructions to impeller arm.
Dec 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dirty dishes
plugged jets, possible
more likely it is leftover food reminance left in the pump area. and on certain dishwashers it could be a swollen check valve, not allowing the evacuation of the used dirty water.
does your soap dispenser open?
May 29, 2009 | Dishwashers
Dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
May 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
76 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
