Question about Sansui CDVD1900 19" TV/DVD Combo
DVD component will NOT slide out. - Sansui CDVD1900 19" TV/DVD Combo
  • 10,594 Answers
You mean On-Screen display wont go away from tv screen that shows component video?
Let me know problem in bit detail to provide you helpful info.
Thanks.
Posted on Jun 06, 2010
  • 3 more comments
  • sandy572 Jun 06, 2010
    No, the DVD component will not slide out to insert a dvd.
  • Shahid Electronics
    Shahid Electronics Jun 06, 2010
    OK,
    Please unplug combo from ac wall socket for minute or so to get it reset, replug back in and turn it ON and check.
    Is it Sansui CDVD1900 combo tv?
    Tried that before, but did it again and it did not work. Everything had been working fine until I tried to insert a dvd last night. Everything else works.
    Any other suggestions?
    Jun 06, 2010 - Tried that before, but did it again and it did not work. Everything had been working fine until I tried to insert a dvd last night. Everything else works.
    It sounds some mechanical issue with disc loading mechanism, I'm afraid, visual check by local tech is needed to fix the problem.
I want to play a dvd on my slide projector is this possible
yes
You need to connect you dvd player to the projector with video leads.
(hdmi, svideo or component) depending what your dvd player has.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Epson EMP-S1H Multimedia Projector
I need remote codes to program my directv control to my bd p-1500 blu ray dvd
hi,
Try any one of the following code.
20490, 20573, 20820, 21075, 20899
Progarmminig procedure
The AV1 and AV2 switch position can be used to program a
VCR, DVD, STEREO, 2nd DIRECTV Receiver or 2nd TV with
the following instructions.
1. Turn on the component (e.g. DVD Player) you wish to
program.
3. Move the slide switch under the AV1 (or AV2) icon.
4. Press and hold the MUTE and SELECT keys at the same
time until the green light under AV1 (or AV2) flashes
twice and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of component being programmed. If performed
correctly the green light under TV will flash twice.
6. Aim the remote at your component and press the power
key once. The component should turn off. If it does not
turn off, repeat steps 3 and 4 trying each code for your
brand until you find the correct code.
7. Repeat steps 1 through 6 to program a new component
under AV2 (or AV1).
ok
Feb 21, 2011 | Samsung BD-P1200 Blu-Ray Disc Player
How do I install more memory to an Acer AX3400? The drive is in the way and can't see how to remove it. Helllllp! ! Thanks. Matt
Aaah! good old acer and their inability to build a pc with user accessable parts! (I have one too).
On the metal frame holding the dvd drive, there will be either a slide clip or small tabs. unlock the drive and push the drive out toward the front. If it moves a little then stops, remove the front of the pc by gently pulling the tabs at each corner of the front facia and fulling it off. Once the dvd drive is moved out, disconnect the power and data cables from the drive. this should give you enough room to insert the new ram. Be careful when adding components to a pc, make sure you are earthed - leave the power cord plugged - in but switch the power off. this will give you an earth. touch the chassis of the pc before you install components to make sure you don't discharge static electricity into the components or motherboard.
Jan 25, 2011 | Acer AX3400-U3032 Desktop - Black...
The DVD player slide draw will not open or close
Check for a manual eject slide on the bottom near the front of the tray
Nov 21, 2009 | Philips DivX DVD Player
A DVD is stuck inside the TV
Do not touch any components on the circuit board. Remove jewelry, wear safety glasses and gloves. Remove all the screws from the back with an arrow pointing to them and any screws on the bottom holding the PC board in. Discharge the tube if it is a CRT by grounding a screwdriver to the chassis ground with a clip lead. Slide the screwdriver under the "suction cup" on the tube with the large red wire coming out. Disconnect all the connectors from the PC board and write down how to reconnect. Slide out the PC board and retrieve the disc from the DVD mechanism. Reassemble
Aug 22, 2009 | Mintek Televison & Video
I cant play my dvd on my infocus LP280 projector
Please provide us with more details like the DVD player make/model and what is the connection cable you are using.
Normally, you should be able to connect the DVD player through the AV out pins and connnect it to AV in of the projector.
Other options that can be used are:
S-Video connector, component video connectors, and DVI-D connections
Please reply for more help and clarifications. Thanks.
Aug 05, 2009 | InFocus Office Equipment & Supplies
Need codes for proscan to put in direct tv remote
phone_header_def.png saveupto_a.png phone_callnow_def.png DIRECTV Specials DIRECTV Packages DIRECTV Receivers DIRECTV DVR DIRECTV HD DIRECTV vs. Cable DIRECTV vs. Dish DIRECTV Sports Home > Remote Codes DIRECTV Remote Codes remote_codes_header.jpg TV CODES VCR CODES DVD CODES STEREO RECEIVER CODES
STEREO AMPLIFIER CODES DIRECTV RECEIVER CODES
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
May 06, 2009 | Proscan 32LA30Q Television
Need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Jan 14, 2009 | Directv RC23 Remote Control
You just dropped me without answering my question or really even trying
I can see you are frustrated so I'll see if I can help. Here are the Akai TV codes:
10812, 10702, 10030, 10672, 10060
As you can see, they are 5-digits for the direct remote, not 4.
This should help!
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Hope this helps
Happy New Year!
Chris (ziraffa)
Dec 31, 2008 | One For All URC-3021 Remote Control
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
Jan 26, 2008 | Audio Players & Recorders
Sansui CDVD1900 19" TV/DVD Combo Logo
24 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
