Question about Samsung Digimax S630 Digital Camera
When you turn it on, it "click's " and the thing on the front won't come out
  • 115 Answers
Go on to your settings and try fixing it from their but if that doesn't work take it to someone that can repair it i think it'll be cheap so goodluck:) and please rate this solution...
Posted on Jun 06, 2010
Front turn signals won’t work rear ones work but fast have checked everthing can’t find a relay under dash
Replace bulbs in front would be the 1st thing. If that doesn't fix it check the wiring between the switch and the front turn signals. The rear ones flash fast to indicate a problem with the front signals. Usually the bulbs are out in the front.
Nov 04, 2017 | Cars & Trucks
I have a 1977 Suzuki GS400X, I get power to all
you may have a bad flasher needing replacement. just because you hear it click when you turn on the signals does not mean the bi-metallic strip inside is working.
Sep 21, 2014 | Cars & Trucks
Dryer makes clicking noise but won t start
The heating element is working or the belt is slipping.
the drum does NOT turn?
See manual. un plug and pop the front off to see if the belt is attached.. Try to rotate the drum by hand.
Aug 26, 2013 | LG Dryers
159 battery
ck for electrical short draining the bat. recheck batt could be defect. ck all electrical devices in the car to be sure they' re working. A alarm system is a big drain (if u have one)
Feb 04, 2018 | Cars & Trucks
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
2004 buick rendezvous sometimes won't start. clicks but won't turn over. replaced starter, battery, and ignition switch. what now??
We just went through this with our 2003 Rendevous. Clicking like crazy but wouldn't start. Replaced the starter but still doing the same thing. Our next step was going to be replace the battery (which tested well) and the ignition assembly. Out of frustration, I hit the top of the hood and the headlights came on!! Further investigaton proved that the problem was a corroded ground wire on the battery. Hope this helps
Aug 06, 2012 | 2004 Buick Rendezvous
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Sony 42" won't turn on
TWO things to look at---inspect the lamp this model should use for brightness. Look to see what lights on front of set are on or BLINKING.
Jun 08, 2012 | Sony Grand Wega Kf-42we610 42-inch...
Kenmore front load dryer won't heat and timer broken
The most likely cause is the timer is bad. It turns on and off things as it cyles through and the first step is to get the tub turning before it turns on the heat.
Jun 01, 2012 | Kenmore Dryers
I have a Maxx Classic WAE20261AU/01 front loader. The machine won't start because the door won't lock. The door has been playing up a bit for about 2 months, but now it won't lock at all. It is...
Sorry. It seems that I have fixed it by using your solutions!
I drained it and cleaned the filter thing down in the bottom right hand corner, put it back to gather and then it turned on again!
Interestingly I found a bobby pin down there!
Thanks for your assistance John_Cross!!
Jun 21, 2011 | Bosch Washing Machines
Samsung Digimax S630 Digital Camera Logo
62 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
