Question about Samsung LN32A550 32 in. LCD TV
TV made a high pithed sound then screen turned grreen...turned tv off...then back on and now have no sound or picture...the on light is on...however now I cannot turn off the tv without unplugging it
I had exactly the same problem with a 2yr old LN32A550P3F. I ruled out the power supply as all of the capacitors appeared to be ok. I was able to find an exact replacement for the main board online and decided to replace the board. That took care of the problem and I now have a working TV again.
Posted on Mar 03, 2011
My samsung lcd makes a high pitch noise when try to turn on and there is no picture
Check and replace the damaged component/s at its T'Con board. In most cases, T'Con board might need replacement. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 23, 2016 | Samsung LN40A530 40 in. LCD TV
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
How do I fix my model tv No picture but knocking sound?
The knocking sound is the high voltage trying to fire. That would tell me that the high voltage splitter has failed or one of the 3 picture tubes (not lamps) has failed. Most likely too expensive to repair a TV that old.
Sep 12, 2015 | Sony Televison & Video
Why does my Samsung LED TV have sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 30, 2014 | Samsung Televison & Video
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
When TV is turned on, there is no picture but a very, very faint verticle haze in the middle of the screen. At first, the power switch lamp is green and blinks slowly, then at a faster pace. At the same...
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Jun 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
High pithed whistle when tv is on through S/sound
If this is an audio question then let's assume that there are differing grounds between each unit.  There are devices on the Internet that show that they can remove any background sounds between two devices with differing grounds.   http://www.beststuff.com/audiovideo/xitel-s-new-ground-loop-isolator-stops-speaker-hum.html
Could you have plugged in an analogue stereo into a digital output on your tv?
If it is a component inside the tv then this may answer the question.  I found a high pitched ring in a tv i owned once.  It was a fixed coil inside that wasn't factory glued tight enough to not vibrate using it's magnetic field.  it looks like a ferrite rod with magnet wire wrapped around it but just one layer and only about an inch high.  It is probably similar on your tv.
Nov 17, 2009 | Cell Phones
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
Samsung LN32A550 32 in. LCD TV Logo
245 people viewed this question
Jerry Greenberg
Jerry Greenberg
