Question about Mitsubishi WD-52631 52" Projection HDTV
Replaced the bulb but tv continues to shut down
Replaced the bulb as i have twice before but this time the tv conrinues to shut down and the red lamp light comes on
    Problem Solver:
  • 5 Answers
Radadtoo,
My wd 62525 was acting the same way. Then after a couple days, started flickering and scrambling the picture. I found neals solution # 2 at this link and replaced a few capacitors and 4 hours later, its all fixed!
Here is the link, scroll down to solution # 2 to get an idea of what the caps and boards look like.
http://www.fixya.com/support/t155026-flickering_blue_picture#SameProblemContinued
Any bad capacitor will be oozing out of the top or just bulging on top. And this took a little time and patience to do. Be sure to label all your connectors and screws.. It really helps
Posted on Jun 06, 2010
What do I do if my mitsubishi tv shuts off after 2 to 3 minutes and shows a solid red light code, which is saying the bulb is bad, I replaced bulb twice and both bulbs are new. What could be wrong?
What model is the TV? Also, what brand is the lamp? A lot of cheap lamps are truly junk and will not work. The bulb should be made by Osram or Philips.
Sep 11, 2016 | Mitsubishi Televison & Video
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Samsung hls4266wx/xaa tv. tv stays on for a minute, then shuts down Timer lamp flashes and temp standby
I put a lamp in to my Samsung HLS4266WX/XAA, but when I actually took it apart for the Bulb replacement which I have done twice now. I found where that switch is, that gets pressed when you have the back cover to the bulb screwed in was hanging, and I can get the new bulb and my replacement bulb to work for about 15 secs, and at one point it was working really good. Can anyone help me with this problem, cause Im getting frustrated. It seems like a simple fix,but its almost like the bulb I ordered is not as good as my other replacement bulb.Its from MWAVE.com, anyone heard anything about this company? Please help if you can, id really appreciate it.
Joe Red
May 21, 2011 | Samsung HLS4266 TV
Hello, We have the Panasonic project TV (PT-50LC14). We purchased a new bulb this past July. We're now experiencing problems with the TV. After turning it on for less than 5 minutes, the TV shuts off. ...
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Regards
Jan 01, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
XL 5200 bulb replace and tv still down
3 blinks means the lamp cover door is nit properly attached. Remove the lamp door and reinstall it
May 28, 2009 | Sony KDS55A2000 55" HDTV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Mitsubishi WD-52631 52" Projection HDTV Logo
155 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
