Question about Porter Cable Cable 4.5 Gallons 150PSI Job Boss Oil - Free Mobile Air Compressor - C3151
UNLODER DOESNT RELEASE BOGS DOWN BLOWS FUSE
UNLODER DOESNT RELEASE BOGS DOWN TRIPSBREAKER IS IT POSSIBLE IT THE TANK CHECK VALVE?
PORTER CABLE C 3151 JOB BOSS
  • 59 Answers
The non return valve to the tank is certainly the next thing to look at .
Posted on Jun 06, 2010
Porter cable compressor will not shut off
Electrical contact points may be welded together preventing them from separating
Mar 29, 2017 | Porter Cable Air Tools & Compressors
Porter cable 6 gal pressure switch. safety valve blows when tank filling
Depending on the pressure in the tank when the safety valve releases,the problem is likely your pressure switch. If the pressure is at or above 160 psi when it blows, then the problem is the switch.If the pressure is lower, then it is likely a faulty safety valve. There are about 8 versions of this machine. check on dewalt service net for the correct part. you may need to check ebay if the part is nla thru dewalt.
Jul 06, 2014 | Porter Cable C2002 150 Psi 6 Gal...
Porter cable C2005 type 3 compressor
There is an relieve valve, usually it is combined with Pressure Switch. You probably need to replace that.
Or even better to replace with Digital Controller.
Check this site: www.CompressorController.com
Nov 28, 2013 | Porter Cable Air Tools & Compressors
Compressor keeps blowing release valve
Compressor pressure switch not working properly. Remove cover over pressure switch. Drain air out of tank. pressure switch contacts should open. If contacts do not open they may be stuck or welded close. Remove power and gently pry contacts apart. If they where welded together this will correct. If this doesn't correct replace pressure switch
Jan 16, 2011 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
I just purhcased this air compressor and cannot get any pressure to bulid in the tank. Even when the drain valve has been closed, there is still air being released. Any thoughts?
This a new machine correct. Did you let it run with the valve open for the 15 minitues this seals and lubes the pistion Ihave the same machine and i know how noise it is aswmeing the pump is pumping there are 3 other paces it could be leaking.The blow out valve the regulator or the inlet hose if the drain is closed.You are going to have to run your hands around the the regulator area and the hose something must be leaking and you won't be able to hear it. It dose have a one year warranty mabey you just got one with a ploblem mine work find i've had it for almost two years with no complantes good luck
Jan 15, 2011 | Porter Cable C2002 150 Psi 6 Gal...
When I plug in my Porter Cable job boss compressor it barely turns over and usually blows the breaker. Any thoughts?
If this happens with no pressure in the tank then you may have a bad start capacitor on the motor.
If this only happens after the tank is full of air then you need to make sure the check valve is working and releasing the head pressure from the lines.
Sep 27, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Will not build up pressure just keeps blowing out the release valve.
release valve is 'stuck' likely from corrosion as compressed air builds up moisture.tap on side of valve or more likely remove & replace
Sep 28, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Extra fitting on my Porter Cable?
CANT FIGURE OUT WHAT YOU HAVE. IF ITS ON THE REGULATOR - THE REGULATOR USUALLY HAS AN INLET, OUTLET, GAUGE PORT AND A PLUG IN THE OTHER SIDE IN CASE YOU NEED TO MOVE THE GAUGE. SOME MANUFACTURERS PUT SAFETY VALVES IN THIS PLUG PORT. IF THIS DOESNT FIX IT GIVE A LITTLE MORE DETAIL. IS THERE ANYTHING WRITTEN ON IT. HOPE THIS HELPS, JODY
Apr 26, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Porter cable pancake unit blows air after shut off.
those have a reed valve set up you need to pull the head off and you will see two strips of metal that are usually held down with two small screws each the one on intake side most likely you could get a rebuild kit cheap it will only have new reed valves maybe new screws for them a leather ring and a head gasket
Mar 14, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Porter Cable Cable 4.5 Gallons 150PSI Job Boss Oil - Free Mobile Air Compressor - C3151 Logo
375 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
