Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The unit turned on blinked about 4 times and will not come backk on RCA D52W20
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If any of them is puffed up on top replace all the 3 capacitors CP150 2200UF 16 other 2 are 220UF 35v they will be green with gold writing on them. Resolder all pins on Fly Back Transformer (FBT) also; also you might have to replace FBT if it’s bad. Please check the power supply also and check the SMPS and in any event replace CP 120: 330UF/35V/HF & CP 150: 2200UF/16V/HF (May be bulged or vented). Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
Rca d52w20 blinks 3 times, wont turn on
The set has a three strikes and you are out rule---tries to come on three times and then if fails, shuts down.
A short exists inside the set.
Mar 17, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca D52W20 does not wanna work
Unit may need service on the video PC board. Have it checked out
Jul 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
when it shuts down and you try to turn it on again does the led blink/ If so how many times does it blink? let me know and I will try to help you out with the problem. Also let me know does the picture do anything abnormal just before it shuts down?
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
