Question about Sharp SX9860 2-Channel Amplifier
I have an amp. It shows no light but I can hear it come on.. What should I do?
    Scholar:
  • 66 Answers
Check all fuses. Sounds like the power supply might be working, at least the transformer which you hear. Try fuses first then that's all you can do, unless you are a tech. You might have to remove the cover to see the fuses, and then again some fuses might not be a glass type. For you, only look for glass fuses. Make dang sure there is no power plugged in when you do this. A visual check for you is enough, as to explain how to use a meter would just be confusing. If you find a blown fuse ( the center wire is broke inside the glass) then take it out if it isn't soldered and make sure you get an exact match. After you replace it, if it blows again or still doesn't work then you need tech help. find a ham operator with techno skills, or take to a shop.
Posted on Jun 08, 2010
Engine will not crank
You need amps to crank the starter. Volts of the horn and lights. Get the battery load tested.
Oct 26, 2014 | Garden
I have a Toshiba 1080i DLP hdtv.. my son & i were
the lamp exploded it happens u need to replace the lamp ensure its the exact type, the lamp is the light source and without light the dmd cannot sync colours nor pix
Jul 10, 2013 | Televison & Video
Maxator 1tb external hard drive - flashing light? not wworking?
Don't know if you are on Windows 7 or not, but this might help a bit
click here for more information
and this is a handy disk optimizer that might help a bit too
May 14, 2012 | LaCie Computers & Internet
I wired my technics 1210 turntable up to my usual audio set up and although it shows itself to be working, there's no sound coming from the speakers. Can anyone shed light on this?
First put your finger on the audio imputs for the deck in your amp. They should buzz with the amp switched on. If you can't get them to buzz, then the magnetic cartridge pre-amp in your amp has failed. If they do buzz. Take the wires to the cartridge off (make a note of where each one fits). Then with the amp powered up and deck plugged into it. Touch each wire one at a time with your finger. You should hear a buzz on two wires (one on the left one on the right) and nothing (much anyway) on the other two. If you don't hear any buzz there's something wrong with the connection cables to the amp. If you do hear the buzz, then the cartridge is dead.
Feb 15, 2011 | Technics SL-1210 Turntable
I have one nokia1110 mobile phone. When i make or receive a call i can hear the voice of the person speaking but no one can hear my voice . need a solution
open pcb & select multi meter at ohmic value
check connectivity on mic pad at pcb if shows anythink connectivity just replace mic if does not shows anythink when you checked connectivity find wich contact are brokened
Method;how find wich pad are broken
place one probe of multi meter on pcb ground & check both pad of mic on pcb when does not shows connectivity on any pad of mic remember it after that arrenge other same type pcb & place any probe on mic pad that you identified & check connectivity at near about when shows on multi meter full conductivity & remember it now resold jumper between mic pad & that part that you searches in your foulty circuit board
Jul 09, 2010 | Nokia 1110 Cellular Phone
No incoming video
The fault is at their end not yours as they can see & hear you. If in MSN messenger, there is a small icon of a camera next to window where picture should be, click on it & select show webcam. Hope this helps.
Have a nice day.
Oct 02, 2009 | Logitech QuickCam Communicate STX Personal...
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
Have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Sharp SX9860 2-Channel Amplifier Logo
181 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
