Question about Malibu ML200RTW - Low Voltage Power Pack -200 Watt - With Timer and Ground
How do I do the wire connection to the transformer? i have a single wire leading to 2 up lights. this is a Malibu 200 watt with 3 connectors on the back.
    Scholar:
  • 130 Answers
I'm assuming that you have a cord that has 2 leads, similar to a black extension cord. Connect one lead to the farthest one on the left screw, skip the middle screw, then connect the other lead to the right screw. Why they did this might be because they used a standard terminal block on all their product and were too lazy to take out the middle screw.
Posted on Jun 06, 2010
Dusk to dawn sensor for 24 v light system
Malibu transformer is 12 volt AC
They make a photo eye for ML300-600-900 watt units, but not for 75-100 watt units
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
Gene
Water Heater Timers Save Money
Oct 04, 2013 | Malibu ML200RT - Low Voltage Power Pack...
How to connect wires to back of transformer with plastic connectors
Wires connect to terminals A and B
1) Copy following link for full resources on operation, wire length, bulb wattage, warranty, troubleshoot, etc
2) Add comment Dec 2012 for more qassistance
Dec 15, 2012 | Intermatic Inc. ML121RT Malibu Low Voltage...
Lighting transformer and wiring
Open following link for ML200 and other models of low-voltage transformer timers, for instructions, wiring, tips and troubleshoot:
Jun 22, 2012 | Malibu ML200RT - Low Voltage Power Pack...
I put in a new 200 w Malibu LV. It worked one day, then only one light would work. The next day it worked again on all lights then it went back to lighting only one. I'm using a combination of 12 LV...
I don't have repair for defective transformer.
The transformer puts power on the wire. Buy multimeter and check voltage across the terminals.
If wires are loose, or bulbs are not connected to wire, or bulbs burned out, or if wattage of bulbs is mis-matched with transformer wattage, then lights might not work as expected.
Aug 16, 2011 | Intermatic & Malibu& 300 Watt Power/Pack...
We have a Malibu/Intermatic timer on our landscape lights. This is the second one we have had and it is approximately 4 years old--200W. The last 2-3days, the lights come on at the time that is set but...
The ground shields are _required_ when connecting submersible underwater lights and 12 volt submersible pumps in water gardens and such.
As a licensed electrician, I must tell you to immediately unplug the power pack (transformer) from the 120 volt outlet and _DO_ NOT use it again until this problem has been solved. This is a definite FIRE HAZARD.
Based on what you stated, I strongly recommend replacing the existing 200 watt power pack with an Intermatic ML300RTW Malibu 300-Watt Power Pack or similar 300 WATT transformer.
ADDITIONALLY, I strongly recommend replacing the _entire_ existing main cable run with Intermatic ML12210 Malibu 100-Foot 12/2-Guage Low Voltage Cable. Make sure to get 12 gauge wire.
There are a few things going on here. First, the transformer is being overloaded. I suspect that you are running pretty close to 200 watts or more. Because the tranformer is overloaded it overheats and the solder in the built-in internal thermal overload melts and disconnects the circuit. When the transformer cools some, the solder in the overload solidifies enough to re-establish the circuit. If this cycle is allowed to continue, either the transformer burns out due to heat or starts a fire.
While these transformers are supposed to operate at full capacity, they will wear out quicker when operated in such a manner. For best results, don't operate the transformer at over 80%. For a 200 watt transformer that would be 160 watts ( 200 watts x .80 = 160 watts).
Secondly, I also suspect that the cable has been damaged, possibly when the siding was installed, and there is a short in the cable, which in turn is overloading the transformer. It's also possible that the end of the cable is shorting out.
In this case the only safe solution is to replace the cable. Even if you decide to keep the existing transformer and reduce the total wattage by using smaller watt bulbs or removing some lights, I still highly recommend replacing the cable.
Sorry to be so harsh about this, but this is a _serious_ matter. You've already had a fire in the mulch and melted the vinyl siding. If you don't feel comfortable dealing with this matter, please call a _qualified_ electrician.
Aug 26, 2010 | Hardware & Accessories
Transformer problem
Malibu power pack has to match total watts of bulbs
15 bulbs each 20 watt = 300 Watt power pack
10 bulbs each 20 watt = 200 Watt power pack
Mar 01, 2010 | Malibu ML200RTW - Low Voltage Power Pack...
Malibu Lighting Breaker Switch
There are two possible problems you could be facing (excluding the transformer going bad) If you have replaced light bulbs with higher wattage ones, you could be drawing too much current through the transformer. (It is common for MR-16 style lightbulbs to be 20w in landscape lights, but 50w for inside lights, and the local hardware store usually only carries the 50w replacement lamps) Each transformer has a specific amount of "watts" it can supply (anywhere from 100w to 1000w) If you exceed the supply wattage of the transformer, the breaker inside the transformer will trip. The quick and easy way to test this is to take a few of the lightbulbs out and see if the breaker will hold.
If you are positive that the total lamp wattage does not exceed the rating of the transformer the second possible problem (but less likely) is that you have a lamp socket or wire connection that is full of water. This water between the two conductors draws current just like a light bulb and can cause an overcurrent fault. This is usually more common if it starts to trip right after a heavy rain when the ground gets saturated with water.
Good Luck!
Jan 20, 2010 | Malibu Intermatic Inc. ML121RT Low...
Malibu ml200rt internal wiring schematics
If you have a meter you can test for 12 volts AC on the output of the transformer. They go to terminals
A & B
Jun 22, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ML200RTW - Low Voltage Power Pack -200 Watt - With Timer and Ground Logo
105 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
