Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
How to change a belt on a bissell revolution vac 37604
  • 276 Answers
Follow the link below to www.bissell.com for belt change video.
http://www.bissell.com/VideoRating.aspx?id=1556
Posted on Oct 13, 2010
The belt for the maain vaccume broke off and now with the new belt the roller will not work.
It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
Bissell Roller Brush for Lift Off Bagless
Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
My liftoff revolution smell like it is burning after I use it
That means that the belt is worn and is starting to slip. You need to replace the belt. Here is the belt you need and a manual you can view with instructions:
Bissell Lift-Off Revolution Belt and Manual
Mar 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
It won't pick up. I cleaned all of the filters. what next?
I would try changing the belt. A worn, stretched or broken belt can cause the vacuum to not pick up well. Here is a link to the belt you need and the manual which has instructions:
Bissell Lift-Off Revolution belts and manual
Nov 17, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
My bissell lift off will not pick up, there are no blockages and suction is still strong
You can fix it easily. All you need to do is change the belt and you'll be good. Here is a link to the belt you need and the manual which has instructions.
Bissell Lift-Off Revolution Belts and Manual
Bisslll Lift-Off Revolution User Guide
Nov 15, 2009 | Bissell 3750 Lift Off Bagless Upright...
I have the bissell pet vacuum and it wont **** up anything I cleaned everything and it still wont pick up
It could be the belt. It the belt is worn or stretched it won't pick up the way it should. I would try changing the belt if you haven't recently. You can get the belts you need and the manual here:
Bissell Lift-Off Belt and Manual
Nov 14, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
I have a 3760 lift off bissell. Replace the torn
Did you get the right belt size? The belt you should have bought is this one:
Bissell 3760 Belt
Nov 08, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Not picking up cleaned all of filters is there a belt for this
It might be because the belt is broken, stretched or worn. In all of these cases the vacuum won't pick up well. You can get the replacement belts for this model and download the manual which has instructions on how to change the belt here:
Bissell Lift-Off 37604 Replacement Belts and Manual
Nov 05, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
The brush is not working anymore
Your drive belt is probably broken. They usually need to be changed every 6 to 12 months. If you haven't replaced the belt recently I would try that. You can get the belts you need through this link and also view the manual which has step by step instructions on how to change the belt. hope this helps!
http://www.vacbelts.com/bissell-lift-off-revolution-pet-vacuum-belt-.htm
Oct 25, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
176 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
