Question about Broksonic CTSGT8118T 13 in. TV/VCR Combo
Need Broksonic tv codes for Comcast Motorola remote for DTA box. Codes supplied don't work.
Program remote for comcast
Check these codes: 11144, 11240, 11331
programmmming TVTV control
The Comcast DTA remote control is preprogrammed at the factory to operate the DTA receiver. The Comcast DTA remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold Setup until the Red Light blinks twice, then release Setup.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Jul 16, 2012 | Olevia 227-S11 27 in. LCD TV
Need a remote code for comcast dta to work with my GPX TDE1380 tv dvd combo
There is no setup codes for GPX with Comcast DTA remote control.
Apr 23, 2012 | GPX TV6000 9 in. TV/DVD Combo
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Jan 10, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Need TV codes for using the comcast DTA remote
I just went through this last night with combo, similar model. They tell you to use the power off test to see when you've got it - nothing worked for that. Then I tried the Panasonic codes and used the volume control as a test, which is much more important, and I found the 3rd code worked for that. I figured, close enough for me, and better than nothing.
Sep 09, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
try these codes for broksonic 10236,10463,11911,11938, 10030,11935,11929
Apr 25, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Need code for my comcast remote
Comcast says that if the codes listed in the instruction brochure provided with the remote (10236 and 10463 for Broksonic) don't work, you should code 991 into the remote and then press the CH+ button repeatedly in order to search through the library of installed IR codes until the TV turns off, then press SET once to lock the code. This worked fine for me, although I must admit I had to press the CH+ button well over 100 times until I came across the proper code in the library to turn the TV off. Unfortunately, there is no way to know what 5 digit code this represents so that if I need to reprogram the remote in the future, I will need to go through the same time-comsuming process all over again.
Feb 20, 2008 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Broksonic CTSGT8118T 13 in. TV/VCR Combo Logo
585 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
