Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
We have a Hampton Bay ceiling fan (about 10 yrs old) don't know the model. It will only turn 1 speed? When trying to change speeds with the chain pull it stays the same. It quit working for a while and I took the light cap off and moved some wires and it started working again. Can the speed control be changed? If so how can I get one. Thanks Jimmy
  • 736 Answers
The fan changes speed by inserting a capacitor of different values in series with the motor .. direct drive to the motor is the fastest speed .. a large capacitor in series slows it down a bit and a smaller capacitor slows it down more ... so if your fan is running at full speed all the time then one of the capacitors is shorted or the switch is bad .. if its stuck on one of the lower speed settings then the switch has a bad contact .. the capacitors are mounted together in a small box with several wires going to the pull chain switch .. you can replace the capacitor box .. and you can replace the 3 or 4 position switch ... or you can remove all that stuff and put in a remote controled system .. that involves a box that just fits inside the fan .. it is hooked to AC power and neutral .. it then hooks up to the lilght and the fan giving you control over both .. you can vary brightness and fan speed .. you would no longer need the fan or light pull switch or the capacitors ... you could also get a new fan having such a controller .. since yours is fairly old it might be worthwhile to upgrade .. some of the remote controls allow you to set a temperature ..if the room goes above that temp then the fan turns on automatically and the speed is determined by how much higher the room temprature is from that set value .. some remotes also give you an additional very low fan speed .. thats nice at night when you just need a gentle breeze .. some also allow you to set a delay before the lights go out after you have clicked "turn off" ... that gives you time to exit the room or get in bed before the lights actually go out ... kindof nice features that might make it worth while to up grade .. to get parts for your old fan see this URL
http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
since Home Depot sells hampton bay .. then they might have parts as well .. worth a try .. you can also see new models there ..
Posted on Jun 07, 2010
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Remote-Wall-Controls/Hampton-Bay/N-5yc1vZbvmuZp4
Apr 03, 2017 | Hampton Bay Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Fan not moving fast
mcdevito75 here, The small pull chain you use to turn the fan on is also the fan speed switch, simply pull that cahin 1 more time and then 1 more time after that for various fan speeds.
Jul 25, 2010 | Hampton Bay 24002 Ceiling Fan
Hampton bay ceiling fan works, but can not change speed or stop fan. Model 46006 52" Huntington III. Is there an easy fix?
your pull chain for the fan is bad u can go to home depo & buy a new pull chain but when u replace it on the back ot the switch their is A 1,2,3,4, make sure the wires go to the correct #'s
Oct 05, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton Bay Deluxe Ceiling Fan SKU: 293972 Never got any but high speed. receiver # as-cf118??remote has 3 speeds. What is wrong?
you need a new remote and receiver. mine did the same thing after a few months an then it completely burntout in 2 yrs
Oct 03, 2009 | Hampton Bay 52 In. White Redington...
I just had a Hampton Bay fan installed, and the pull chain will not change the speed. It stays on high speed.
Replacement switches can be purchased at Orchard supply, Ace Hardware, Lowes, or Home Depot. After checking the wiring at the switch - connections made during fan installation - and no faults are found, switch should do it.
May 04, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Jan 03, 2009 | Hampton Bay (261025) Dual Mount Ceiling...
Hampton Bay CF No Model #!!!!
I had this exact same problem at an apartment i lived in awhile back. Unfortunately, there IS no was to change speed or direction. It is a one-speed, one-way fan. Sorry for the bad news.
May 31, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
436 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
