Question about Elite Sl 3000 Ul Sliding Gate Operator
Elite Miracle One abruptly stops with no slow down
I have an Elite Miracle One that has been working for years. After a recent rain storm it no longer slows down before the positive stop. Do you think this is a controller board issue? I also noticed that the red and brown brake wires that are connected to the swing arm lead to a shorted connection inside the motor. Is this normal? Or could there be a short inside the swing arm? I wish I had a schematic so I could better understood how the brake functionality works.
  • 1 more comment
  • james281 Jun 06, 2010
    I already have the manual. The solution steps offered are things I have already tried. I am looking for a solution from someone who knows this particular product better.
    As stated before I have the manual already. I want to know if it is a normal state for the brake leads on swing arm to be shorted. This could be a normal state, but I need to know before I order a replacement circuit board.
  • james281 Jun 08, 2010
    I'm looking for someone with more specific knowledge about the schematic of the product. The first item I need to know is whether there should be continuity between the brake terminals on the motor. They appear to be shorted together. Is this normal? Second, if it is a normal state what tests can I conduct on the control board to determine whether it is faulty. I am capable of testing voltage, amperage, resistance, etc. Thanks.
    Brigadier General:
  • 4,090 Answers
Take a look here for an exploded parts diagram
http://www.operatordepot.com/miracleparts.html
and here to download the manual
http://www.operatordepot.com/pdf/miracle1manual.pdf
The shorted out section sounds like it might be the problem. But comparing this with the installation manual and diagrams for wiring should help you
Thanks for using FIXYA
Posted on Jun 08, 2010
  • 11,896 Answers
This would be either a control board or power supply/power suppply board. The supply would be the first thing I would test with a voltmeter. There should be a label on the unit that says the DC Voltage Output on it to match the voltmeter's reading.
Posted on Jun 07, 2010
  • 10,865 Answers
Hello. As you probably know this is the cadillac of gate openers. That said, a shorted connection is never a good sign and always the first place to look deeper. Here is the manual http://www.amazinggates.com/Do_It_Yourself/web/Manuals/Elite-SL_3000-manual.pdf
Posted on Jun 06, 2010
  • 12,061 Answers
Http://specs.chamberlain.com/pdfdocs/0150593.pdf
Above is your manual, this has much information. From what you describe, I would think "Sensor" or "Drive" for the sensor. IF there was a Short, I don't really think, it would actually go? What you need to do, is use the manual and perform the troubleshooting steps, and check all sensors switches, etc. If the windings are shorted, then accordingly the "Drive" too, well, that would most likely be destroyed.. if it is so, you will need to check that too.and replace it.
I've had my emachines for about four years and after a rain storm my tower is not working. When ever I turn it on theirs and error page that shows up. Its been doing that for about two years now.
Hello Aretta,
The storm you referred, you didn't mention if it was torrential rain, or a lightning storm, either way, there could have been a build-up of static electricity on the telephone line and if your P.C. was connected to the internet and to the mains at that time, it maybe the build-up of static earthed itself through your P.C.. If that is the case, then you are lucky it did not kill your machine. My advice is to get an engineer to look at it BUT! don't tell him about the storm unless he asks.
Regards,
Ron.
Jun 07, 2014 | Computers & Internet
How many quarts of transmission fluid does a 2004 yukon hold
Ya. We had the oil shop change fluid $150. (force flushed). They under filled it by a 1 qt 1/2.
Then my son over filled it. Tranny died 4 months later.
Prior to that he drove in a rain storm flood and the nissan has a rediculas air intake dpwn by bumper caused water into cylinders. By a miracle the engine stoped but did not break internally.
Hate the industry. .
May 05, 2013 | Cars & Trucks
Stopped working during a rain storm
Short circuit or fuse blown. Call electrician and check it.
Aug 17, 2012 | Heating & Cooling
Tachometer works but speedometer does not. Just recently happened following a drenching in a rain storm
Take off your front wheel and make sure the speedo cable is positioned well. Try turning the speedo connector. If too easy, you may have broken the cable. Check Cleveland.craigslist.org, a guy in Cleveland deals exclusively in Honda V65s used parts if your cable is trashed. He posts once a week or so.
Aug 20, 2011 | 1984 Honda VF 1100 Sabre
1982 chevy k10 4wd. front left wheel makes a ratchet clicking sound while driving. it slows down as the truck slows down, but abruptly locks into place just before stopping. adding fresh grease seemed to...
Hello, same problem and it should be u joints in the front. My truck sat for a year and all the ujoints are caked with rust and as they near failure they will begin to click much like what you are saying. I noticed it most when going from forward to reverse and vice versa.
Aug 12, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I just recently purchased a 2007 Ford Focus SES that had only 75000 km. I have never driven a car with traction control on it. We had a snow storm, and when I accelerated to about 45 km per hour, I had a...
All vehicles will slide in the snow. Traction control or not. What traction control does, in simple terms...Is when your wheel start to slip, which is detected by some sensors, it lowers the vehicles throttle position, slows the RPM's down, even if your foot is still on the gas, for a matter of seconds, until the wheels stop slipping. So when you feel or hear your vehicles engine slowing down on its own, its best to just let off the gas and let it go for a couple seconds. A way to test the traction control...From a stop, if you are in the snow, and you push the gas down a good bit, make it spin, and the vehicle should seem to power down on its own, while the light comes on, if it does not do this, then traction control would not be working. Hope this helped.
Feb 25, 2011 | 2007 Ford Focus (3 Door) Hatchback
Drivers electric window wont roll up it goes down real slow but wont go up past halfway.Its real slow going down and before this it would go slow and roll outside of track at top
Window regulator and motor assembly will need replaced. Common problem. You've seen other people with it at the drive thru ATM and pick up windows - getting out of there car to get items!! LOL! Seriously have an experienced mech. look into it. Having this thing not work will be a real pain especially if it dies during a rain storm. Good luck
Sep 09, 2010 | Honda Accord Cars & Trucks
Air conditioner won't reset.
If you're trying to reset it right after it trips, you're not giving it enough time for the pressures to equal out.
Also, try again, unplugging it from the wall and waiting about 20 minutes before plugging it back in.
If it got a good surge from the storm, it may have grounded out the compressor.
Jul 16, 2010 | Goldstar KG6000R Window Air Conditioner
Elite Sl 3000 Ul Sliding Gate Operator Logo
420 people viewed this question
Top Elite Home Security Experts
John
jr3261
Are you an Elite Home Security Expert? Answer questions, earn points and help others
