Question about Foxconn 6627MA-RS2H Motherboard
Need specs for the N15235 motherboard.\r\nIt has a
Need specs for the N15235 motherboard. It has a burned out Intell dual core E2220 CPU,
with a 775 platform. What range of Intel dual
core chips will it accept?
  • tallmelp Jun 07, 2010
    the link to solution 1 is missing "intel" at the end minus the quotes. After several attemps I went to
    Foxconn and managed to find the cpu list. Thankyou
    very much.
    President:
  • 2,351 Answers
The link provided by Foxconn shows all supported CPUs that will work on the Foxconn 6627MA-RS2H MB; http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&model=6627MA-RS2H&cputype=
Cheers'
Mike
Posted on Jun 06, 2010
Testimonial: "Except for not being able to use the link because you did not allow enough characters to be used for that line. It was helpful."
  • Mike Peluso
    Mike Peluso Jun 07, 2010
    Not much I can do about that. From time to time the end of some links will not show up. It's easy to open though. Copy the entire link and past it into you're browser.
Audio driver
i don't know what computer you have
Nov 14, 2013 | Intel Pentium Dual-Core E2220 2.4GHz...
I need the best, fastest, most powerful and recent CPU and RAM available for the AcerPower Series 661GX-M7 motherboard; can it use a dual core processor?
Welcome to Fixya. If you want to upgrade your Processor you can use a dual core cpu. I proivded the list of processor that is compatible with your motherboard. By the way the socket of your motherboard is a LGA 775
Lga 775 Processors
Thanbks for using Fixya.
Jul 02, 2011 | Computers & Internet
Does the GA-8I945P-G supports the Core2duo Processor?
No since this is a older mobo the manufactre only recomndes you use Pentium D, Pentium 4 HT, or Celeron D. many people have tried this and have had alot of problems and little success.
May 04, 2011 | Intel Gigabyte GA-8I945P-G Dual-Core CPU...
What is a version of Biostar G31d-M7
Socket LGA 775
Supports Intel Core 2 Duo/Pentium Dual-Core/Celeron Dual-Core/Celeron 400 Series Processor
Supports FSB 800/1066/1333MHz
Support Intel Hyper-Threading Technology
FSB 533MHz is not supported by this motherboard. CPU TDP over 65W is not available. Please refer to CPU support for further information.
hope this helps
Mar 02, 2011 | Biostar G31D-M7 Motherboard
ONN N15235 motherboard, which is a 775 socket. I am currently running a Pentium E2160 on its but its pretty slow so I bought an E5400 to replace it. When I changed the CPU over and started up my computer...
The LGA 775 processor socket doesn't matter, calderwooddu.
It's up to the motherboard chipset, and the BIOS program, and version, of what that Foxconn N15235 will support. I would go back to the Pentium Dual Core E2160, use CPU-Z from CPUID.com, (Free), and see what the motherboard chipset is, first.
(Motherboard chipset: The Northbridge, and Southbridge chips. Chip is slang for I.C. Integrated Circuit)
The Northbridge chip is what determines what Processors are supported.
1) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
2) http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Since the E2160 is built upon the 65nm technology, and the E5400 is built upon the 45nm technology, the Northbridge chip of the Foxconn N15235 may not support the E5400.
With the technology change are also Instruction Set changes. Plus other parameter changes. The BIOS program, and version on the Foxconn N15235 may not support these, either. Sorry to be a bummer.
Not a solution per se, Yet.
Need to know what computer this Foxconn mobo is out of. (MOtherBOard)
OR, if you get the computer operational again, let's use CPU-Z to see what the motherboard chipset is.
Need help in downloading, and/or installing CPU-Z, post in a Comment.
Oct 09, 2010 | Computers & Internet
Which intel motherboard ( model detatil) is suitable for an intel dual core 2.6 Ghz processor?also what should be the capacity of ram that may suitably mathe the intel dual core 2.6 Ghz processor?
Assuming the CPU you have is an E5300 2.6 duo 45nm then use an LGA 775 mobo.
For Win XP / Vista run at LEAST 2gb (Preferably 4GB) Ensure the mobo specs are compatible with the type of ram also.
Dec 03, 2009 | Computers & Internet
I have an IBM thinkcentre m51 that I am trying to upgrade to a dual core processor. It seems that it won't take it. Is there a setting on the bios that will allow the motherboard to support a dual core...
Most major manufactures use motherboard designed to their specs and upgrades to the processor are limited. You can use software such as Belarc Advisor, to determine what motherboard you have and then you can search the net to determine what processors are compatible with it.
Nov 08, 2009 | IBM ThinkCentre M51 PC Desktop
How to install CPU- Intel Pentium Dual Core E5200 into a asus barebone system P4-P5N9300pc please?
This particular CPU is not on the list of processors supported by this board. See "CPU Support List" tab:
ASUS P4-P5N9300 Spec
How to install Socket LGA 775 CPUs:
Lift up the cpu slot load plate (which covers the pins and also locks the cpu in place) and install the processor slowly, vertically and carefully into the socket without bending any of the tiny pins in the motherboard socket. Lock the load plate.
The advent of the LGA 775 form factor moved the tiny pins from the CPU to the motherboard socket. Great for Intel, not so great for motherboard manufacturers. Now bent pins are the responsibility of the board makers. Customers with bent pin problems are no longer contacting Intel.
Sep 23, 2009 | ASUS Computers & Internet
I can't work out what size chip to put on my motherboard
Asus list supported CPU's for your P5S-MX SE Mb.
Click on the link below;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S-MX%20SE&product=1&os=17
The further down you go the stronger the CPU.
When looking for the CPU that you want, you'll also need the bios version listed across from that CPU.
The next link will list everything pertaining to your Asus board.
Look to the left for more information like FAQ, supported CPU & Forms.
(For the link below to fulley open, you'll need to choose your operating system from the drop down menu & click Search in order for the driver link to load);
http://support.asus.com/download/download.aspx?modelname=P5S-MX%20SE&SLanguage=en-us
Use the manual to help you. (Download it needed).
BIOS 0306 is the latest revision & supports the newer CPU's.
Pentium Dual Core E2220(2.4GHz,800FSB,L2 1MB,M0).
Link to some CPU's;
http://www.google.com/products?hl=en&ei=oZEIStOIMpuWMdmEmcwE&resnum=0&q=Buy+Pentium+Dual+Core+E2220(2.4GHz,800+FSB,L2+1MB,M0)&um=1&ie=UTF-8&ei=qJEISshJj7402Mno2AI&sa=X&oi=product_result_group&resnum=4&ct=title
Cheers!
Mike
May 11, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Foxconn 6627MA-RS2H Motherboard Logo
3,209 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
