Question about Amana Portable Air Conditioner
I bought an Amana Portable AC 12000BTU model AP125D without a manual. Worked great last year. This year it will not turn on. The red light blinks on and off
4 Suggested Answers
skrbin
  • 121 Answers
SOURCE: my portable amana air conditioner ap125d will not
decrease a temp. on thermostat
Posted on Jul 05, 2009
  • 17 Answers
SOURCE: Thirteen and a half month Amana Portable AP125D
Contact the dealer you bought it from.
For warranty information, please call HSN.com Customer Service at 800.933.2887 (8 am-1 am ET)
If it is out of warranty, and you can get hold of the parts, then as long as you feel confident to change the parts yourself, go ahead. It will only be a case of removing the case and maybe some covers inside to get at the broken components. There is NO rocket science used in the design or building of these things.
All you will need is a small to medium sized phillips head screwdriver and maybe a 7 or 8mm spanner. You may need to cut a couple of cable ties. Make sure you note how the components fit and also the route of the cables as they will need to be routed the same way when you replace the case.
You need to discover what caused the fan to break in the first place. In my experience this cause is normally someone poking something into the grill...
Posted on Aug 15, 2009
freetek
  • 5568 Answers
SOURCE: I have an Amana portable AC, Model # AP125D. When
This indicates a problem of electrical leakage inside your AC and it should be inspected by an electrician for your safety GFIs trip due to an imbalance of current between the 'hot' and neutral lines which means that current in traveling from the 'hot' line through some path to the ground (safety pin on the plug). If you use any method to fool the GFI (there are some) you should anticipate having nasty shocks from any exposed metal on the AC; not good idea.
If a professional finds no fault, it is quite possible that the GFI itself is failing; I have replaced several which were tripping on insignificant events.
Posted on Jun 22, 2011
I have an Amana portable AC, Model # AP125D. When you turn it on, it trips the GFI. Can you help me. Thanks.
Jun 22, 2011 | Amana AP095R Portable Air Conditioner
Thirteen and a half month Amana Portable AP125D AC. Last week noise asif something hitting fan, than after trying to determine problem over the next three days the fan at the rear bottom of the unit broke...
Aug 14, 2009 | Amana Portable Air Conditioner
REAR PROJECTION HDTV ISSUE
Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in. While these can be repaired, the cost of that will approach the cost of a new assembly.
Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
Jul 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
J.v.c. big screen tv 56-58 inch
my jvc big scrreen worked just fine last night and this am i turned it on and the color is greena and red with double vision can you help
May 25, 2008 | Televison & Video
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Psp
There are batteries that at 20% of charge left go off and keep blinking if thats your problem, just connect ac cable den put battery and restart manually. I have a similar battery
Dec 12, 2007 | Sony PlayStation Portable (PSP) Console
Amana  Portable Air Conditioner Logo
177 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
