Question about Sony DVP-NS730P DVD Player
I have a Sony DV-NS730P and it is currently not
I have a Sony DV-NS730P DVD player and it is currently not working and has an error ''cannot play''. I wonder is it a major problem and is it worth getting it fixed.
  • 748 Answers
Hi
Depends on what you paid for it. The error is an indication that either the laser head is misaligned or defective or the motor or associated head/motor electronics is defective.
Posted on Jun 06, 2010
Testimonial: "many thanks for your feedback, the problem started with saying all discs are dirty now it just does not play."
By mistake, I selected RGB connection while setting up in sony DVD NS730P. Now the screen goes blank means output switched from DVD component connection to RGB port. How to return back to DVD componeent...
Please press the DISPLAY when the player is in stop mode.
The Control Menu appears.
Press the up/down arrow to select SETUP, then press ENTER.
Press the up/down arrow to select the RESET and then select Yes from following message.
Press ENTER.
It will reset the player.
Jan 13, 2011 | Sony DVP-NS730P DVD Player
While watching a DVD my Sony DVP-NS30P failed completely, presumably the power supply. Is this common and is it relativly straight forward to fix? Thanks Neil
Yes! the power supply is the issue, I have found the main filter capacitor in some units opens stopping the power flow, if that is the case the repair is simple to correct.
Jan 01, 2011 | Sony DVP-NS730P DVD Player
I have same problem. Am unable to connect my Sony DCR-HC28 to my computer. I have tried different cords to different computer, but get the same error that the device cannot be read
Try to connect to dvd RECORDER and make dvd, then finalize it. It works perfectly and there is no need for software. Then you can play it even on the computer or any dvd player. Good luck
Oct 04, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Unlock sony DVP-FX720
The problem may be you are trying to play DVDs from a specific region (Europe) and the player is set for another region. Region code errors will show up as "no Play" or 'region" Check the manual to see how to set the player to Region 0. A region machine will play any DVD. Sometimes the setting is on the menu - usually in the set-up screen under "region." I have re-set all my Phillips players to become Region Free through the menu.
Aug 22, 2008 | Yamaha DV-S5450 DVD Player
Playing recorded DVD's on my current DVD player
alot depends on type of disc and certain players- if -r disc make sure it was finalized-if you try a -rw it may work unfinalized right out of cam-there is always the posibility your dvd player may never play them-belive me it is a ton of trial and error-i have 5 players in house and when i burn video it doesn't always work in all of them!
May 26, 2008 | Video Cameras
Picture in Black & White
if you are using composite cables (yellow,red & white), make sure your yellow (video cable) is into the yellow output. if you plugged the wire into the green on the back of the dvd it will give you a black & white picute. But if it is in the yellow then you most likely have a problem with the dvd player that will need to be taken to a service center.
Nov 01, 2006 | Sony DVP-NS730P DVD Player
Sony DVP-NS730P DVD Player Logo
99 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
