Question about Maytag EPIC MFW9700S Front Load Washer
Maytag epic z out balance repair man came and said they are all that way. i leveled it and tightened the legs and it still balances around. HELP
    President:
  • 2,702 Answers
He's telling fibs! there not that way at all,,,,
did he look inside at the shocker springs? if one is missing becouse its broken off ,,,the washer learn's to dance about!
get him back for a proper fix and not a con job!
Posted on Jun 06, 2010
FAV6800AWW won't spin without going out of balance
Each of the legs supporting the washer need to be adjusted and the washer leveled. You will need a Level with bubble indicators to see the exact position of the liquid within & it is in the center of the glass container. Level front to back and side to side. When done the washer should be level at all 4 sides and it will not move around and cause the level indicators to trip any switches.
Mar 05, 2014 | Maytag Neptune FAV6800AW Top Load Washer
The tub easily goes out of balance and loudly hits the sides during spinning.It sounds like a very loud banging drum. Repair men (yes, men) failed to repair the problem. Lifting the lid and moving the...
Thanks for choosing FixYa and welcome to the site. As you already know, that is the reason that it is doing it. You need to check the bottom legs of the washer and make sure none are damaged. Also, I would advise you to get a level tool. By doing this, you will know where the balance is off at. You can add wood slits under the legs to balance them off. Once it is level, you should be good to go.
Apr 19, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My washing machine makes a loud thumping noise when it goes on a high spin cycle, especially when the load is large. The problem started to become worse once I reconected a shock that was not connected...
The biggest problem with front loaders is leveling. Be sure it is sitting level. Use a lever and not your eye to level the machine. Be sure to use the lock nuts on the leveling legs. Also, these machines are very heavy and need to be on a really solid hard surface. Hope this does it for you.
Good Luck
Mar 12, 2011 | Kenmore Elite 45986 Front Load Washer
The Maytag PAV 2300 does not spin right if the load is slightly off balance. It bangs on the side and ordinarily lists to the right. On inspection, the washer is on level.
The list to the right should be resolved. Use a level and level the case left and right, and front to back. The final step is to tilt the machine fully on to the front legs, releasing the self leveling rear legs, and set the machine back down. It should be stable on the 4 feet.
usually this will center the drum and it is more forgiving on balance issues, most of which are common. Be sure to use MORE than enough water for more even loads.
Feb 05, 2011 | Maytag PAV2300 Top Load Washer
I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Oct 06, 2009 | Maytag Performa PAV3200
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
Hiya .. would suggest you having a look at the balance around the drum, ( normally heavy concrete blocks)... locate the fixing bolts and tighten them up ....should sort your prob.
Also make sure that the washer is fairly even and tight on its legs.. this is what usually causes the problem in the first place..
Regards Faggly
Mar 27, 2008 | Maytag Performa PAV3200
Maytag EPIC MFW9700S Front Load Washer Logo
155 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
