Add Printer to computer - Computers & Internet
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    What's your printer make and model # ? What's your operating system?
    Problem Solver:
  • 5 Answers
Check to see if driver software is in your add and remove programs try uninstalling it and try adding the driver for the printer again if that does not work goto add and remove hardware .Do a add new hardware scan if you don't find it that way try finding it in the manufacturs software scroll down and see if your printer is in there click on it and fallow the instructions. If that does not work call the manufacture about problem.
Posted on Apr 10, 2008
Change printer
you must uninstall the old printer first then do this.
  1. Click the Start button, and then, on the Start menu, click Devices and Printers.
  2. Click Add a printer.
  3. In the Add Printer wizard, click Add a network, wireless or Bluetooth printer.
  4. In the list of available printers, select the one you want to use, and then click Next.
More items...
Fix printer problems - Windows Help - Microsoft Support
if you have any trouble goto this link..
For Seniors How to Install Printer for Your Computer dummies
Dec 23, 2016 | PRINTER Office Equipment & Supplies
Printer crashes computer
Simple tip to fix this issue is to Index your Computer and Add Hardware based on the Test Results:
Windows Experience Index rates up your computer. You can add appropriate hardware based on the search results.
  • Click Start.
  • Press ENTER.
  • Windows Experience Index will launch.
  • Click Rate this computer button to start conducting the tests.
  • After these tests are completed, you can get the overall performance results.
You are advised to add new hardware based on the search results. For example, upgrade your processor, add more RAM and add a Graphics Card.
For Instant Fix use Reginout system utility.
Jan 16, 2013 | Oki Electric Industry MB290 A4 Mono Laser...
I can't connect the printer with my laptop. The printer is connected to my main computer and I'm trying to get my laptop to recognize the printer.
You will need to add this printer as a network printer using the main computer as the server. This is easily done, but is different for each operating system.
winXP= start>settings>printers and Faxes>add a printer> add network printer (next will search for printer)
- sometimes you must share the main computer by opening windows explorer and right clicking on the c: and select sharing and follow the screen
- Hope this helps, send more info if you need more help
Aug 28, 2011 | HP PSC 2210 All-In-One InkJet Printer
Want to install printer
If you are running Windows XP or Windows Vista, you may simply plug in the printer to the computer, and the computer will install the generic driver.
By default, Windows XP and Vista already has the generic driver installed.
However, if the printer is not a Plug-n-Play device, you will need to load the CD that came with the printer, and follow the installation wizard.
Thank you and good luck!
Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer status reads "printer offline"
Could be several things causing this. You said it is a network printer, but then said primary computer is XP. Is it hooked to the XP machine? From my experience, printers on XP machines occasionally lose their drivers. Go to the XP machine and make sure the printer is in the printer folder, and active. Do a test print to be sure. Then make sure it is still shared (things like this can change with updates). If all this is OK, go to the Vista machine and remove the printer. Then go to add printers, and add a network printer. Sometimes, if it is a network printer, it will show up in "my network" - if so, right click and add printer. If you add the printer usually the computer will use the currently installed drivers. If it is a shared printer, go to network, double click the XP machine, and the shared printer should be there. right click and add. Once you have it working, go to printers and delete or remove the faded-out printers that don't work and be sure to set the newly installed printer as your default.
Sep 06, 2017 | HP OfficeJet 7310 All-In-One InkJet...
How do I network brother mfc-440cn printer - what
  1. Plug the printer into a computer on your network.
  2. This computer must be on and remain on for the printer to work.
  3. Add this local printer to this computer in "Control Panel" - "Printers".
  4. Now share the printer.
  5. Go to another computer on your network.
  6. Add this printer (as a network printer) to this computer in "Control Panel" - "Printers".
  7. The system should find the printer and add it...
Nov 15, 2009 | Brother MFC 420CN All-In-One InkJet...
How do I get my computer to print from the printer?
Have you installed it yet? Click "control panel" on computer, Click "printers & faxes", in Printer tasks on left side of screen click "Add a printer", then the add printer installation wizard should come up. Follow the instructions and you should be right. Good luck.
Apr 03, 2009 | HP 7210 OfficeJet All-In-One Printer
Printer installation
On the computer that the printer is connected to, go into the Printers and Faxes window, RIGHT click on the printer you want to share and select "Sharing...". After you finish going through the printer sharing wizard, go to a different PC and try to add a printer, select network printer. Make sure that the computer that is sharing the printer is on during this process, it sounds strange to have to mention this I know but you would be surprised. I'll check back later to see how things worked out.
Feb 21, 2009 | HP Office Equipment & Supplies
Add printer to computer
All you have to do is add a driver. Download the driver from here:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Then install and restart. Viloa! Your printer is installed
Jan 31, 2009 | Lexmark All-in-One Printer with PictBridge
Epson printer and windows vista wont talk to each other
Windows Vista should automatically detect and install devices attached to the computer. Simply connect the printer to your computer and power it on.
If the driver does not automatically install, you can follow the steps below to install a resident driver which is part of Windows Vista. The resident driver installation should only be used if the printer is not detected and installed.
1. Click on START, CONTROL PANEL and PRINTERS.
2. Click the ADD PRINTER button. If you do not see ADD PRINTER, right-click in the PRINTERS window and select ADD PRINTER from the menu.
3. The ADD PRINTER wizard window will appear select Add a Local Printer.
4. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
5. In the next window select EPSON under Manufacturers and your printer model under Printers.
6. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
7. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
8. Once the test page has printed, click FINISH to exit the wizard.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The RED error light will flash when the printer is low on ink and go solid when it is out.
-If the ink levels do not appear, click GET INK LEVELS from the MAIN tab of the printer driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
Jun 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Computers & Internet Logo
David Payne
David Payne
