Question about Groove Tubes 2009 GT Bump BMX Freestyle Bike (20Inch Wheels)
When i try and lift the front wheel it wont lift up
  • 66 Answers
If you mean when you are riding you need to lean back over the back of the seat as you pull up to get the front wheel off the ground
Posted on Jun 08, 2010
Possible reason why 04 chevy tahoe 4wd works up in air on lift but not on ground
the residual force makes it look like its working on a lift ,
check your wheel sensors the speed sensor determines how fast each wheel is turning say in the snow , if the sensor fails it wont go into 4 wheel drive.
Feb 19, 2015 | Cars & Trucks
Got a 2004 Ford F-150 transfer case i gauges front drive shaft turns but front axle does not lock into 4 wheel drive what could be causing issue its a shift on the floor lights for low come on but not high...
Check your hubs lift front end if wheel does not turn when locked in 4x4 then hubs are not engaging turn wheel by hand or a pipe wrench on drive shaft do not try power unless all wheels are lifted
Jan 02, 2015 | 2004 Ford F150
Front drive shaft wont turn when enaged and up on stands
if the back wheels are still on the ground then it will not turn until you lift one wheel of the ground. In 4wd the front and rear drive shafts are locked together. There is no diff in the transfer case.
Dec 13, 2014 | Cars & Trucks
HOW TO FIX MY 2007 IMPALA AFTER SLAMMING BRAKES IT WONT MOVE IN DRIVE
Jack up 1 tire at a time and see if a wheel is stuck. Make sure you do this on a level surface and you block the back wheels when you lift either of the front tires. I am guessing but a calliper is prob jammed but could be a bad wheel bearing collapsed or something else binding in the front drive train.
Nov 19, 2014 | 2007 Chevrolet Impala LS Sedan New Cars
All wheel drive dont work
there is an actuator in the front axle that engages the drive shaft to the wheels. there is also a vacuum actuator i believe in that model it is under the battery plate. if you put on lift you can trace the cable from the front axle back to the actuator and check the cable, actuator and vacuum lines. Gm's system is complex and when is messes up its a night mare. but common failures are actuator cracked or broken vacuum line.
Jan 11, 2014 | 2004 Buick Rainier
Wheel bearing
If grinding noise is heard coming from front side, lift up both the front wheels and rotate the wheels one by one to listen to the sound, if any. If a noise is heard, replace the front wheel bearings as a set.
If the front wheels do not produce any abnormal noise when rotated, lift down the front vehicle. Lock the front wheels with blocks, release the hand brake. lift up the rear wheels and try to listen to the abnormal noise. If the noise is heard, replace the differential bearings and seals. Top up the differential oil to the mark.
Dec 12, 2013 | 1998 Toyota Tacoma
My four wheel drive wont engage but my light is on on my 05 nissan xterra
YOU NEED TO CHECK THE HUBS FOR PROPER OPERATION LIFT THE FRONT END TRY TO SPIN THE TIRE U WILL KNOW BY THE AMOUNT OF FORCE IT TAKES TO ROTATE THE TIRE
Sep 26, 2013 | 2005 Nissan Xterra
I have a ford f 150,v8 engine and my 4 wheel drive wont work now, can it be just a fuse?
Is the system ESOF ( Electronic Shift On the Fly ) or MSOF ( Mechanical Shift On the Fly ) ?
Lift and support the front of the truck so the front wheels are off the ground ( take safety precautions, chock wheels, jack stands, etc )
Key on, engage 4x4 and try to turn the front drive shaft.
If it turns it is a problem with the transfer case.
If it doesn't it is a front axle engagement problem.
I would suspect that the front drive shaft does not turn, and the issue is with the vacuum lines for the front axle.
You can check the vacuum lines with the engine running, and have a vacuum gauge on the front disconnect motor. Pink line is 2WD operation ( unlocks the front axle ) Light Blue is the 4WD operation ( locks the axle ).
The disconnect motor is on the front axle, item #10 in the picture below
Picture of it.
Dec 10, 2010 | 1998 Ford F150 Regular Cab
4x4 front end not engaging
my computer problem is hard disk system found warantty hard disk
Feb 24, 2010 | 2006 Ford F-150
95 nissan 4x4 truck. four wheel drive light comes but does'nt en
the front axles have pinon gear box that the shaft from the transfer case goes to, it has a vacuum hose to it or a solenoid actuator check these for proper function this is how the power is turned on to the wheels.
Feb 13, 2010 | 1990 Nissan Hardbody King Cab
Groove Tubes 2009 GT Bump BMX Freestyle Bike (20Inch Wheels) Logo
106 people viewed this question
Top Groove Tubes Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Groove Tubes Cycling Expert? Answer questions, earn points and help others
