Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Installed new ice maker, produces ice slow, is there a way to adjust for faster or slower?
    Scholar:
  • 44 Answers
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Posted on Jun 06, 2010
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Maytag MFI2665XE
    The ice maker was an option that was installed where you bought the refrigerator. Most all ice makers work in a similar fashion. The device that tells when the ice tray is full may need an adjustment.
    Sep 19, 2017 | Maytag Refrigerators
    Slow ice production
    If your unit is making ice and is not shutting down on any faults then you need to check to make sure the condenser coil is not dirty or the air filter. also where is the machine located? If an ice machine is sitting in a warm to hot location then the slower it makes ice.The cooler the air around the unit entering the condenser coil the faster it will make ice.
    Feb 13, 2014 | Scotsman Kitchen Appliances - Others
    Icemaker is slow in producing ice
    If your icemaker is producing ice, but it is slow, there are 2 likely explanations.
    1. Temperature. Water freezes at 32 deg, but the icemaker won't eject the ice until it gets below 10 degrees. If you always had good ice output and all of a sudden it has slowed down, you're temperature is a little higher than ideal. Check for a door seal not making good contact or try dropping the temp in the FREEZER side a couple degrees
    2. New model. Most new refrigerators make ice much slower than older models to meet energy efficiency guidelines. This is not a repairable issue.
    May 25, 2012 | GE Refrigerators
    Ice maker not putting out water just hooked up ice maker kit
    Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
    Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Ice maker not producing ice. Changed the water solenoid valve and the ice maker. still no ice! what is the problem here. how can i remedy this.
    Good Day,
    Obvious but,
    Shut water off to house at the meter. Remove supply line to water valve. Place end in a bucket, have someone turn on main valve for a 15 second count. Should have a hard steady supply from the line into the bucket.
    If no joy, and this is common,
    Remove Ice maker and see if ice has built up in supply tube from outside back of machine into the rear of the ice maker.
    If iced, defrost, but caution. Heat guns, hair dryers ect. can do more harm than good. Go slow.
    I do not recommend heat because of all the plastic and vinyl. Just shutting down the machine by unplugging it, and air drying.
    P.S. I've installed brand new ice makers and valves that didn't work out of the box.
    Nov 18, 2009 | Kenmore Refrigerators
    Slow making ice. It is taking forever to fill the ice bin. What can I adjust to make it produce ice faster?
    Clean the coils under the ice box so that the flow of air cools the condenser mo propah my amigo.
    Jun 14, 2009 | LG LSC26905TT Side by Side Refrigerator
    Replaced icemaker with new one but still not working
    The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    The ice maker has completely stopped producing ice
    The ice maker is producing ice poorly
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
    Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
    ICE MAKER.
    ADJUSTING WATER FLOW WILL CHANGE THE ICE MAKING TIME UP. TO DO THIS PULL OFF COVER ON FRONT OF ICE MAKER AND ADJUST SCREW ACCORDENLING. HOPE THIS HELPS
    Sep 25, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
    Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
    134 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
