Need to replace a carrier air conditioner model #YCB243D with a compatable unit that fits same case
kstfas
  • 75 Answers
SOURCE: Air Conditioner malfunction
Hi, Sounds like you have a short in the control circuit to me. Turn off all power going to the unit. Write down or otherwise mark the wires leaving the control board going to the thermostat. Remove them from the control board. Replace the fuse. Turn power back on and see if the fan still runs. If it does, check and or replace the heat limit switch that brings the fan on during the heat cycle. It may just need adjusted. If the fuse blows, I would think that the control board is probably bad. If it doesn't blow, Remove the thermostat. Leaving all thermostat wires open check them with an Ohm meter. There should be no continuity between them. Twist all the wires together at one end and ohm them again at the other end. You should have complete continuity on all wires. If the wiring checks out, down power the unit. Double check your wire colors and rewire the control board. With all wires open at the thermostat, turn the power back on. Touch the RED wire to the YELLOW wire. The Condensing unit should come on. Touch the RED wire to the GREEN wire. The fan should come on. Touch the RED wire to the WHITE wire. The heat should come on. Down power the unit. Replace the thermostat. Test unit. If the fuse has lasted ok but blows now it is either wired wrong at the Thermostat or the thermostat is bad. I hope I have helped. NOTE: If you can not understand these instructions. Call a licensed Heating / Air conditioning company. kstfas
Posted on Sep 23, 2007
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 18 Answers
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Posted on Dec 11, 2008
  • 189 Answers
SOURCE: air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Posted on Apr 14, 2009
pillarair
  • 17 Answers
SOURCE: size and year of Carrier
3 ton air made in 2003
Posted on Jul 21, 2009
CARRIER FILTER FOR MODEL FA4BNF030
I can't find a filter to fit my Carrier air conditioner it needs 16 1/2x21 5/8x1 where can I find this can you please help, thank you
Jun 25, 2012 | Carrier Heating & Cooling
Would like to replace carrier ycb243d a/c with another brand using existing case
prerry hard to do I have not ever seen it done 30 years at this ..
Aug 04, 2011 | Heating & Cooling
I have a condensor Carrier model 38ck030300. It is old and I cannot read how many tons it is. I probably need to replace it with new. Do you know how many t it is? Which units will be...
The unit is 2.5 ton system. many units can replace the existing, you can upgrade to a 3ton if you wish without problems or upgraded ducting if enough ducting exist.
Brands that will almost fit as is are Payne, Day and Night, Rheem, Ruud.
Jul 26, 2011 | Carrier 38CKC036 Air Conditioner
Is it a 110 or a 220?
Hello SUEK,The plug end WILL not fit a standard outlet if it is 220v.IT gets a special plug/outlet match!
Jul 26, 2010 | Carrier YCB243D Air Conditioner
Can you put a 410a air handler with a r22 condensor
No. R22 and R410 are not compatible. R410 units operate at much higher pressures than a comparable R22 unit. These refrigerants also use different types of oil which are not compatible. If you need to replace half you might as well replace the whole unit because I was told that as of January 1 of this year you can no longer buy an entire R22 unit unless it is one a dealer still has in stock. They are phasing out R22.
May 19, 2010 | Carrier 38CKC036 Air Conditioner
Air conditioner replacement--new size required?
Apr 14, 2009 | Carrier 38CKC042 Air Conditioner
I need a remote for a carrier bca-101r wall unit. Or a compatible remote.
Get model number and call place of purchase or carrier customers service.
Mar 19, 2008 | Carrier BCA101R Air Conditioner
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
