Question about SVA-USA VR-15BU 15 in. Flat Panel LCD Monitor
Monitor problem Hi, my wife and I had downed powerlines after a major storm, and the lights started flickering inside the house. After the problem was fixed I noticed my monitor had a message floating around the screen saying no video hardware available. Can you please help us?
    Novelist:
  • 119 Answers
Dear Booker3772,
From what you have written I assume you do not have a UPS system protecting the PC.
Unfortunately this mean that hardware has been damaged as electricity spikes have caused electrical stress to the components.
It would be helpfull to me if you where giving me a little bit more information but I will try to help. There are a few possibilities though that can narrow down the problem.
1. When you power up the system nothing happens - No noise no fans nothing. - Solution: The complete PSU or the fuse within is fried. (Change PSU and fire up again)
This is the most likely cause but these are also very possible.
2. When you power up the system the system fans, lights, hard disks make noise but you see nothing in the monitor except the sign. (The monitor's voltage regulation pcb is fried due to the storm) Try with a spare monitor if possible and if possible try the monitor to another PC
3. When you power up the system the system fans, lights, hard disks make noise but you see nothing in the monitor except the sign. If the monitor works fine, the PSU and the components seem to run fine most likely the components within the PC have been damaged. Not to the extend that a total failure is present but enough to create a mess. Some of the components will still probably be in good condition though. The only way to test them is by interchange one component with another.
In any case if the PC is still under warranty please go to a repair service centre and simply say that it stopped working. Do not mention storms, its your liability normally to protect the PC.
Regards
EngineerGR
Posted on Apr 10, 2008
Have 3 or 4 Maestro dimmers in house. After a storm it seems that they flicker every now and then at lower settings.Other lights in the house seem fine. Do they flicker every now and then normally. Check...
No, they're not supposed to be flickering, regardless of the light-level. I can't think of why a power outage would cause the lights to flicker all of a sudden. My first suggestion, check the lamps - make sure they're incandescent or line-voltage halogen lamps. If they're CFL or LED, then flicker (particularly at low-end) isn't just possible - it's likely. Other sources of flicker - sometimes the power companies install new metering equipment that throws some jitter on the line that cause issues - not much you can do about that unfortunately. My primary suggestion is to call tech support at 1-800-523-9466. It's free, they're available 24/7, and can probably offer more suggestions than what's available through doing this over a web-site.
Apr 14, 2011 | Lutron ELECTRONICS MAW-600H-LA SMART...
Monitor flikkering .i will check the VGA cable and power cable both are properly connected but the monitor is flikkering .what i do
Answer Sometimes if the refresh rate isnt set high enough you will see a noticeable flicker on the screen .. to change the monitor refresh rate .. you can right click on the desktop and then left click on properties .. click on the setting tab then click on the advanced tab then click on the monitor tab ..look in the drop down menu where it says 60 hertz and see if the refresh rate can be changed .. if it cant .. uncheck hide modes the monitor cant see and then click on the drop down menu .. pick a refresh rate .. 75 hertz is what i use and it should stop the flicker
Answer
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Answer
A nearby device can cause stray magnetic fields that will cause the display to be affected.
A problem inside the monitor will cause the display to have problems.
If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
Answer well one major cause can be the weakness of the electron gun that fire electrons on the silicon plate (pixels) that produces image on the screen so there must be some problem in electron gun in my view
Dec 14, 2010 | Acer AL1511 15" LCD Monitor
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
W2753v screen flicker - refresh
Hi
What causes monitor screen to flicker?
Answer
Answer
Jan 29, 2010 | Computers & Internet
Hi my philips monitor keeps flickering on and off. I hear a clicking sound but the monitor will not stay on.
You are hearing mini-sized lightning bolts.
Turn the monitor off, before it burns your house down.
Disconnect it.
Find a Recycling Station that will responsibly recycle your monitor.
Buy a new monitor.
Nov 01, 2009 | Philips Computers & Internet
Powerline ethernet lost connection
this is usually caused by dirty power, have you installed cfl light bulbs recently?
you might also check to see if any existing full fluorescent lights produce a buzzing noise.
Aug 14, 2009 | Powerline Computers & Internet
GE Advantium Oven - LED lights went out.
if anything like my own it is the led blub thats blowen - major hasel to change out - get some one who knows these cookers/ovens...
Aug 07, 2009 | GE Monogram ZE2160SF Convection /...
No light and stopped running
check the thermal fuse on the blower housing it may be opened(blown)
Apr 12, 2009 | Dryers
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
SVA-USA VR-15BU 15 in. Flat Panel LCD Monitor Logo
85 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
