Question about Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet
Bowel cleaning fresh spatters , specks that stick to the sides and back of the bowl do not flush off as no water flows to these spots. Not enough water not good.
  • 349 Answers
Check the ports under the rim and make sure they are not clogged. To do this you can use a nail or pin to clean them out.
Right under the rim of the bowl are these ports that allow the water to flow into bowl in a turning motion to aid in flushing and cleaning wall's of the bowl.
Inside the tank check the fill tube and make sure it is connected from the fill valve to the over flow tube. Also check the fill level in the tank and make sure water is up to the line on the fill tube about 5/8" from top of tube.
Posted on Jun 06, 2010
Toilet Cistern Sticking
Mechanism that releases and shuts off water should be checked if any part has disconnect or improper connection.
Jul 09, 2013 | Home
Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Jun 30, 2012 | Omega Rear Drive Wheel Snapper Mowers
Water splashes out of toilet fbowel when flushed
Try lowering the float level. This will reduce the amount of water in the cistern and lower the pressure on the flapper so when you flush the water will not flow as fast into the bowl.
May 27, 2012 | Home
Water level in bowl is too low so it's a problem keeping it clean. How can I raise the water level?
All toilet bowls have a preset water level determined buy the design of the internal s-trap and can not be change. However if the water level in the tank is not as high as it should be this will affect the water put into the bowel as the bowel in refilled by the flush valve and if it is set to stop before it get filled to the proper setting the bowl water level may be low.
A quick test is to see if the water level in the tank is up to the line in the tank most all toilet tanks have a line either stenciled or marked with a indentation in the porcelain. Another way is to mark the level in the bowel with tape or a marker then pour water slowly into the bowel not fast enough to flush it wait to see if it stays higher then the mark you made or settles back to that level.
Feb 04, 2011 | Duravit 111335001 Geberit In Wall Carrier...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
Our Toto bowl does not fill up enough after flushing unless the lever is held down. What do I do to fix it? We have well water and a bit of mineral does build up on the fill tube.
The only adjustment available is to control how full the tank will be for the next flush. The water that runs down into the bowl after flushing comes through the same valve that fills the tank, so the problem (and solution) is entirely with the amount of water that runs into the bowl while the tank is filling. The tank is filling sooner than enough replacement water can run into the bowl. Make sure that the tube (usually a 1/2 inch rubber tube) that runs from the float valve to the pipe that fills the bowl (usually a 1 inch pipe with an open top) is actually delivering all of it's flow down that pipe. If the flow of water being delivered by that tube is slow, you will have to find and eliminate the restriction. You might be able to pull of the rubbber tube off of the float valve and stick a small drill bit (just using your fingers, not a drill) into the fitting where you pulled off the tube.
Mar 08, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
When flushed, not enough water flow to empty sides and waste
make sure water level is sat at factory settings. there should be a black line that reads WATER LEVEL. If this is not the problem. then you have calci buildup. get a gal. of muratic acid,plunge all water out of toilet bowl. then dump in at least 1/2 gal. let set over nite. with water turned off. get up turn on water then flush. You mite have to do it twrice. hope this helps you.... duane.
Sep 28, 2009 | Kohler Barrington Pressure Lite Elongated...
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Cimmaron one piece elongated doesn't have enough water in BOWL.
Make a small mark with a pencil or marker that can be erased of were your water line is in your bowl. Pour some water from a bucket into the bowl SLOWLY and see if the water line rises or drops back down to your original mark. If it drop back to the original mark, then that is the way the toilet was made. You won't be able to do anything about it. If it rises and stays at a higher level, then you have a problem with the fill tube in the tank. You will need to call a Pro!
Jan 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet Logo
134 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
