Question about Dishwashers
The top spinning paddle on my simpson silencio dishwasher 950 came off. I was able to re-attach it but I notice that there is no hose for the water to enter the top paddle from - can someone please tell me where this hose would go and where I should be looking. There is an opening at the top of the machine but no attachment from there to the top paddle. thank you.
  • 20 Answers
The end of the spray arm should plug straight into the hole at the back of you machine when you push the top basket in.
Posted on Dec 23, 2010
Our Simpson Silencio 850 dishwasher - the detergent draw is not opening when operating on any of the cycles. Has just recently been happening. Can anyone suggest what might be causing it?
mine did that too. It is not a simple fix, I can not afford a new dishwasher so I did this: I attached a small mesh bag (about the size of a deck of cards) to the bottom rack in the dishwasher. I put a Finish power ball in the bag and ran the dishwasher in the usual way. It has been working fine that way and saved my dishwasher.
Aug 03, 2017 | Dishwashers
Simpson 950
No, most likely you need to add rinse agent and/or dishwasher salt to your dishwasher for it to run properly. If you have recently put in something with a label and it came off in the heat the paper would now be blocking the filter and you should check this too, it would be reachable through a screwtop inside the main body of your dishwasher. If the clog has formed inside the tube that leads out of your dishwasher you could disconnect it and run hot water directly through, you may be more comfortable with a service man but it is really something anyone can do without much need for tools except for a bucket and old junky towels handy in case of slight spillage. Best to turn the electric and water off to it first!
Nov 21, 2013 | Dishwashers
Simpson silencio 980 won't start cycle
HI I think you should take the waste pipe and blow down it you'll need a bit of puff, there's also the possibility that the waste pump is blocked with debris you will need to take it apart to clear it failing that a new water pump may be necessary or if your lucky you can access the pump by tilting the machine after removing the mains lead and the water pipe inlet there should be an isolation tap attached to the water pipe good luck in your task cheers eric
Nov 16, 2017 | Dishwashers
Simpson silencio dishwasher over filling . have c...
Clean the filters and filter bowl and if that doesn't solve the problem check the pipes to the pressure switches on the bottom right side (as you face it ) are not blocked and check that the pressure switches are working by blowing in their tubes and checking for a "click" sound and test with a multimeter for an open and closing circuit.
May 20, 2010 | Dishwashers
Water will no enter my dishwasher
check out you're hoses.. the mice might have chewed through them. that happened to my sister
May 30, 2009 | Dishwashers
Top spray arm not connected to anything so dishes dont wash properly
as long as you have a spout mounted in the middle of the top basket, everything is fine , water will spray from top nozzel (mounted in ceiling of dishwasher) into spout entering spray arm.
May 01, 2009 | Dishwashers
Water not emptying in dishwasher model simpson silencio 850
How long does it take to wash dishes completely in a ASimpson dishwasher
Apr 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Simpson silencio 850 dishwasher. not sure where to put upper wheels for top basket
Halfway and at the end. Put them upside down on the right-hand side to avoid the tray jumping when sliding.
Nov 07, 2008 | Dishwashers
Dishwasher simpson (silencio 850) model 52B850SF * 04
Check that the pressure switch tubes are not blocked on the underside of the machine on the right hand side and that the pressure switches are working when you blow down their tubes. You will hear them click on and off.
Nov 05, 2008 | Dishwashers
Simpson Silencio 850 leaks - the water doesn't seem to stop filling. Replaced all seals, but it keeps filling until it leaks and we have to stop it manually.
Hi, I've just purchased a 2nd hand model of your dishwasher. mine actually leaks from the black lining underneath. I've just patched it with some Sellys bathroom sealant. I don't know more about your problem but sounds like it could be something not timing out to stop the water, maybe buy a new 1 :P
Sep 11, 2008 | Dishwashers
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
