Question about Peg Perego 12 Volt Rechargeable Battery
How long do you charge a pegperego 12 volt battery
    Genius:
  • Peg Perego Master
  • 1,508 Answers
It depends on what the ah is of the battery, usually one hour for every ah that the battery is, so if its 12ah battery then charge it for 12 hours
Posted on Jun 07, 2012
2 Suggested Answers
  • 110 Answers
SOURCE: is there a fuse in the pegperego gator 12 volt
yes, you have to remove the blue cover and then they are very easy to change. just remove the screws.
Posted on Jan 28, 2011
12v battery won't charge replaced inverter and battery got 13.6v coming out of the inverter and only 12 at the battery
inverter problem as it is a required voltage of 14.5 volts to charge a 12 battery ( a fully charged battery is actually 13.2 volts as 6 cells of 2.2 volts each = 13.2 volts )
Jul 24, 2017 | Inverter Electronics - Others
Battery is charged but wont run
Check that the wires for the motors on the rear tires are connected. If they are connected check with a multimeter and make sure that they are showing 12-13.8 volts
Apr 26, 2015 | Polaris Ranger RZR Ride on Toy
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
Fitted new battery, but does not work
check the battery and charger with a multimeter and make sure that they are putting out 12 volts
Mar 05, 2011 | Peg Perego PegPerego "Cub Cadet" Pedal...
My batteries are struggling to charge do i need new ones
Harold Do you mean that they won't fully charge or won't charge at all. If you have the small 12/12 batteries then they do not last as long as the U1 batteries (bigger) If you have the U1 batteries check the voltage of the batteries with a volt meter Fully charged should read over 12 volts and up to 13.5 volts. Also check your charger to make sure that it is charging with a voltmeter you can measure the voltage aith the charger plugged in and you should be reading over 13 volts on each battery. Hope this helps you
Sep 07, 2010 | Pride Health & Beauty
Is there a fuse in the pegperego gator 12 volt battery
Apr 10, 2010 | Peg Perego 12 Volt Rechargeable Battery
Wont keep a charge
You should be able to get over 12 volts from the charging system of the lawnmower. I would think once it is running, you should get 12.8 to just over 13 volts dc to adequately charge your battery. If you have less then 12 v power output from your chargiing system, well then the charging system is not working properly.
Of course, if the battery is defective and wont hold a charge, you can test that be taking the battery out of the machine and checking the voltage. It should be 12 volts or slightly better. If you let it sit overnight and it drops substantially, well it is likely not holding a charge and draining internally. If it does not have 12 volts to begin with and your charging system is ok, well then it is likely defective.
Also, you can use the glass hydrometer made for batteries to draw up some fluiid and check against the colour scale.
Each cell on a battery is 2 volts, so 2 volts times 6 cells is 12 volts. So if one cell is bad, then they all become bad as the battery needs a total of 12 volts to operate.
Some gargages will test your battery for free if you buy the new battery from them.
Sep 21, 2009 | Briggs & Stratton Garden
I bought a used hpx gator, dont know if it has a battery,
In the front of vehicle, just under brush guard, in the center, is a phillips head screw. Un-screw and battery is in compartment. See http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
Dec 20, 2008 | Peg Perego 12 Volt Rechargeable Battery
Peg Perego 12 Volt Rechargeable Battery Logo
201 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
