Question about Planet Audio VX4002 Car Audio Amplifier
Red protection light - Planet Audio VX4002 Car Audio Amplifier
    Problem Solver:
  • 19 Answers
Make sure amp is not grounded out or shorted out like if u miss and touch ground to power or the other way around protect light usaully comes on be resets once u turn the amp power off then back on . if that don't fix it maybe ur amp needs some repairs inside.
Posted on Jun 06, 2010
Should the interex surge protector have both red and green light?
the red may indicate a surge controlled but will no longer protect the equipment
most surge protection is only good for one hit and that fails the protection for more surges
read the user manual on it or go to a retailer and read the instructions on a new unit
Oct 25, 2016 | Televison & Video
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
I have a kenwood subwoofer, the red light comes on but I am getting no sound, help?!
red light is usually bad like protection mode unless it is supposed to be red. amps are always green and red is protection indicator normally. look it up for your amp and if you bought it used you got ripped off
Mar 14, 2015 | Kenwood Car Audio & Video
Is the red light that says protection on the hifonics hifi1001.1d suppose to be on or of? My is not on is that bad
My guess is if there is a fault and it has to go into protect mode the light will come on. The red color is usually stop or warning etc ... green = go or good.
Dec 01, 2013 | Car Audio & Video
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
How to switch protection off (red LED to blue)
The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
No sound no protection light
u must have a faulty wire...recheck youre instalments....or get a professional to do it for you..
Feb 19, 2010 | Kicker ZX10001 Car Audio Amplifier
I bought a MTX Terminator amp and the light is red when I turn it on, but it works. Red usually means protect mode but it works fine. Should the light be red or green?
all depends on that amp... if there was an issue it wouldnt work, and the light would be by a protect symbol... if its just red next to the power symbol i say no issue.
Feb 18, 2010 | Car Audio & Video
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
My sony xplod 1000w xm-1652z doesnt work anymore
First off, according to the manual, the protect light should be green. That's normal operation. If it is red, that's a problem.
If it does go red, disconnect all of the wiring to the amp except the +12V and ground. Short the remote connection to the +12V to force the amp on. If the protect light still lights red, the issue is inside the amp and will need repair. If the issue goes away, try reconnecting one wire at a time until the protect light goes red again.
Mar 23, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Planet Audio VX4002 Car Audio Amplifier Logo
360 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
