Question about Video Game Consoles & Games
I have an old Valley Cougar Ele. coin operated Dart board. It has worked fine until the other day, now it turns on and it keeps flashing different numbers and stuff now and we can't play it. Wonder if anyone had any ideal on it. Or If anyone know where to get a manual????
  • 177 Answers
/www.pinrepair.com/bally/index1.htm#ps maybe
Posted on Jun 07, 2010
My gas furnace is working but the led light will not stop flashing, is it suppose to keep flashing.
A steady heartbeat on the circuit board USUALLY means normal operating condition.
Mar 29, 2015 | Heating & Cooling
Trouble shooting dart boards
Is it a stand up or a wall mount dartboard?
Step one: Will it turn on? (stand up) if yes go to step two
  • If nothing is working verify your AC power cable, (the cable coming from your outlet to the machine) is in good working condition, check for cuts/abrasions/sharp bends/knicks in the wire. If nothing seems out of the ordinary you could then try a different cable. The cable itself is a generic cord and you probably have one lying around somewhere, unlike your cell phone chargers which are not at all interchangeable.
Step two: Will it boot up? (stand up)
  • In older standup dartboards like the galaxy 1 or "bull shooter", a lot of times if it will not boot up or keeps resetting it is because the contacts get dirty over time. Carefully disconnect the main and or secondary line voltage feeds going from the power supply to the motherboard. be sure to slowly pull the connector(s) from both sides as to not bend the small fragile prongs behind it.
  • Then, using a very fine sandpaper, were talking something smooth to the touch, such as 1000 grit or a piece of standard 8''/11'' copy paper, gently wipe off the contacts. (small metal prongs on the motherboard). There will more than likely be brown carbon residue left on your piece of paper.
Note: You would not want to use something abrasive such as regular sand paper or a file; because you will likely have to do this periodically over the life of your dart board.
Step three: Is the monitor/screen not working?
  • Check your connection coming directly from your power supply. there should be plugs, one plug should be going to the monitor while the other goes to the motherboard. try unplugging the cord coming from the monitor and plugging it and checking for defects before plugging it back in.
Step four: connections, connections, connections.
  • Follow all your wires coming off or going to the motherboard and the back of the dart board. Anywhere you see can see a plug or connection verify its tight and follow all your wires while scanning for defects. especially with small wires even the tiniest of knicks or exposed copper should be cut and spliced and wrapped in electrical tape to prevent moisture from corroding the connections.
All i can say about wall mounted electric dart boards is they are cheap and can be damaged very easily. Often times if you threw a dart hard enough it would be more than enough to do some permanent damage or cause malfunctions such as no sound or distorted sounds coming from speakers. All I can personally recommend short of taking it apart and looking at everything is going to walmart and buying another one for 30ish dollars.
Sep 27, 2014 | Sport & Outdoor - Others
Hp pavilion dv4 1280us CMOS battery error code 502
Only the coin battery on board. They come different ways. Mine had a battery with a wire connected, another had just a coin size 2020. Different configurations around but ow days its just a coin size battery.
Mar 26, 2014 | HP Computers & Internet
A couple years ago, I dropped a coin down behind the dash of my van, and it has done something to the insturment panel, at times the temp meter don't work, the speedometer don't work, and the gas hand...
The coin probably has nothing to do with the dash problem. That is a common problem among Voyagers. Here is some more info. that might help you. Problem #1 The blinking lights in the rear wiper rear defrost area can be reset by holding 2 buttons of the 3 on the left hand side. The top and bottom buttons. Turn the key on and hold them for about 10 sec and they should start flashing differently. Just let it do this. After they start flashing different. It will take 5 to 10 mins. Then one or more will quit flashing all together. If they don't after about 20 min reset them again it can take about 5 trys sometimes before they all go out. Also to fix the dash going out try this. This is a common problem with the voyager,caravans and Town & Countrys. What the problem is is a cold soder in the interment cluster itself. The problem area is where the plug comes from the van into the cluster. You need to take the circuit board out of the cluster and reheat the soder on the back side of the circuit board were the plug plugs into. This will fix the cold soder permanitly I think its about 16 pins you have to reheat with the soder gun. If you don't feel comfrotable doing that you can just replace the interment cluster and it will be fine but if you buy a used one make sure it was tested. Hope this helps I have done several of them.
Nov 14, 2010 | 1998 Plymouth Voyager
The key still goes easily into the doorknob
can be easy as wd-40 squirt of oil. try that first... then on to more drastic measures
Dec 13, 2009 | Schlage BE365-CAM BE365CAM620 Antique...
Turns itself off every time I try to take a photo
I had a similar problem with my Cyber-shot S600. It just turned off every time I tried to take a photo. I bought a Sony recharger + batteries and it fixed the problem. Camera works fine and I'm impressed with the how long the batteries last between charges.
Jan 04, 2009 | Sony Cybershot S650 Digital Camera
Flashing green light
I had the same problem with a WS 55813,2004 model.Paid 130.00 for local Mitsubishi authorized dealer that told me I needed a new DM module at an additional 505.00. Called Sears and they repaired the board for 146.00 by replacing four capasitors on the board. The tech said there is an exolaination on the web that explaines how to do this. He said this is a very common problem and carries 8 caps with him.He even had to do this to his own tv. The caps are worth 8.00 total.
Oct 11, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Video Game Consoles & Games Logo
1,636 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
