Question about Rowenta Professional Luxe DM880 Iron
The cord has a sort. how do I find a replacement
The cord has a sort. how do I find a replacement cord
    Scholar:
  • 70 Answers
When you say short, it means to most people that you have intermittant connection in the cord, and one would say, replace it with the same or better type cord. If you are good at soldering, wire splicing and crimping, it should be fairly easy to separate the base using Security Torx Bits (i.e. tamper resistant screws are used), and a bit of judicious patience. Once appart, if they use crimped or solder connections you can cut, splice and crimp as needed. Your cord will be a bit shorter and you will have to reindex the strain relief service loop, but it should be painless. If you are not confident working with UL listed safe equipment (your loved ones will be using this appliance) you can get it serviced here:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Posted on Jun 06, 2010
Replace cord in Rowenta Iron
0) Unplug the iron.
1) Remove the (2 or more) screws holding the plastic bottom plate (that the iron stands up on).
The screws are likely to be #20 Torx "Security" screws -- for which you will need a special bit for your nut/screwdriver. A kit of various sizes of Torx security bits will cost you about $10.
2) Remove the plastic cord-holder assembly from the iron.
2a) If the cord-holder is held in place with screws (you are in luck!), simply unscrew them. If you see no screws, then it is being held in place by several (probably 4) plastic tabs that you must simultaneously release. This makes the job much more fiddly. Use a small/medium blade screwdriver to carefully bend and hold each of the plastic tabs out of the way of the latches. You'll need one screwdriver per tab/latch! Take care not to break the tabs...
2b) Carefully wiggle/pull/work the cord-holder assembly out of the iron taking care not to bend the pins of the integral plug (inside the iron) that are seated in the cord-holder socket. Basically, with the iron resting on its metal surface, pull/pry/wiggle the cord-holder straight upward until the cord-holder (socket) pulls free of the (3 or more) stiff wires that function as a "plug".
3) Note that there are 2 crimp-on connectors attaching the 2 wires of the cord to the rest of the wires in the iron. Take a photo of the wires and jot down notes of which wires are connected together. NOTE: One of the cord wires is "neutral" and is attached to the wider spade at the plug end of the cord. Typically the "neutral" wire is marked with a white stripe or ridge down length of the cord. Don't mix up the "neutral" wire and the "hot" wire when you re-connect them in a later step!
4) Cut off the crimp-on connectors and separate all the wires.
5) Remove the cord from the system of zig-zagging "strain-relief" notches that hold the cord securely in place. You may have to remove a small plastic clip first.
6) Cut off 6 inches of the cord. (Or supply a new cord, if the cord has been shortened too much in previous repairs.) This eliminates the broken section wire within the cord. You may use an ohm meter to verify that both wires have a low resistance again (less than 1 ohm).
7) Route the cord back into the "strain-relief" notches in the cord-holder. Don't forget the plastic clip (if there was one)...
8) Strip all wires, exposing about 3/8" of copper on each.
9) Referring to your notes and photo, re-connect all wires using proper-sized plastic wire-nuts for secure connections.
10) Re-attach the cord-holder to the iron body. Make sure you line up the stiff wire pins with the cord-holder socket. Push the cord-holder into place and secure it (via screws or snap-in-place plastic tabs).
11) Replace the plastic cover, taking care to position the wire-nuts and wires to allow it to drop into place without forcing it. Secure the cover with screws.
12) Plug in the iron and test it out!
Mar 23, 2014 | Rowenta Irons
Electric cord is working sometimes
You have a short in electric cord. If you choose to replace cord be sure to replace the entire cord. Do not attempt to repair a damaged cord as this may present a fire hazard.
Jan 27, 2014 | Sunbeam Irons
I am having problems with my cord when I move the iron the iron shuts off. How do I fix this problem? DM880.
just replaced the power cord, you can buy wire and plug then assembled it to the iron and replaced the old power cord which may cause of shut off.
Nov 28, 2012 | Irons
When I plugged iron in sparks came out at wall and iron where the cord connects.
If you've had this iron for a while it sounds like the cord may be frayed.
switch it off at the wall and unplug it, check the cord for wear, if the insulation is frayed, torn or broken and there are black burn marks on the cord where you saw sparks then the cord needs to be replaced.
DONT plug the iron back in until the cord is replaced.
Otherwise If there are no breaks or black burn marks on the cord, then your power point may be faulty and needs to be replaced!
I hope this was helpful
MobileJB
Jul 13, 2011 | Oreck Cordless Speed JP8100CA Iron
My Pro Finish 714 cord was accidentally cut. Is it worth replacing the cord? Where do you get a new cord and can I replace it myself?
Thank you for using FixYa. Is the cord cut near the iron end or the outlet end? could the cord be shortened? A new cord can be purchased at most reasonable hardware stores and with a little care and attention can be replaced yourself.
Hope this has been of some help.
Mar 04, 2011 | Black & Decker ProFinish X750 Iron
No power from cord. I want to replace the cord.
In replacing the cord, you have to remove the screw that holds the back cover and unscrew the damaged cord from the heater terminal. Insert the new cord on the rubber insulator and screw it to the heater terminal.
Nov 04, 2010 | Euro-Pro Shark GI490 Iron
I need to replace the cord on my steam iron. Can i bring it someplace to have it replaced or can i do this myself?
If you can use a screwdriver you can probably do it yourself. Take all the screws out of the handle which should allow you to get to the cord. Determine how they have it attached to your unit. If it is spade lugs there could be a problem. If it is soldered there could be a problem. If they are screwed on we can proceed. Remove the wires and hookup your new cord which could be an old extension cord which is no longer any good. Put your unit back together and you should be good to go.
hardrocko
Thanks for using FixYa and the generous rating.
Mar 04, 2010 | Rowenta DG-980 Iron
Oreck Cordless Speed Iron
Try an Oreck store or customer service.
If not I would suggest Ebay or something of the sort that would have odd and end parts
Sep 06, 2009 | Oreck Cordless Speed JP8100CA Iron
Cord short ccircuit
The back comes straight off. All you need to do is take a small screwdriver and pry against the bottom metal piece, then it should start to come off. Make sure you take it off carefully so as not to break anything. Pry evenly all around the plastic end cap until it comes off.
After that, you can replace the cord. It's connected via two crimp caps. Easy to replace. Just make SURE you purchase a cord rated for an iron.. DO NOT clip the plug end from an extension cord or similar and use it. The iron uses 16 gauge HEATER CORD. Easy to find, but you could melt your power cord and possibly cause a fire if you don't replace it with the correct type.
Mar 13, 2009 | Black & Decker D2020 Iron
Rowenta Professional Luxe DM880 Iron Logo
271 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
