Question about D-Link DI 514 Wireless Router (DI-514)
Settings will not save. I am trying to save a security key so my network will be secured but the settings will not save.
    Guru:
  • 868 Answers
Are you getting any errors?
if not try pressing the pinhole reset on your router usin a small pin or paperclip to reset the router press that reset button for about 5-7 seconds then let go, wait for a couple of second for the modem to reset then go back in and try putting in your security key make sure you do this connected to the router via ethernet cable ^_^ before going wireless.
security keys work depend on the operating system on XP WEP will do, in vista WEP and WPA, in Win7 WPA2 personal.
Posted on Jun 06, 2010
3 Suggested Answers
  • 13433 Answers
SOURCE: Wireless security settings on laptop do not match network settings
Hey,
As the settings don't match, I would recommend you reset your router, theres a reset button there, hold it for 30 seconds, your router is returned to default settings and you will instantly get online after the router is working.
After this you will need to setup some security settings incase you don't want people to freely connect and use your network.
Let me know how it goes.
Thanks,
Ekse
Posted on Sep 06, 2008
  • 10406 Answers
SOURCE: Can't get the Linksys Router's list of Network Security Settings
The router has a built-in web-server.
So, just connect your web-browser to that web-server,
select the correct page, and click PRINT.
Posted on Jan 01, 2010
Testimonial: "Need more info...Thank you."
Setting up a new modem
After you press the reset. Your laptop has to be physically connected to the router to configure it
Open your web browser, type in "192.168.1.1" and login using username and password.
In "Basic setup" DHCP Server should be "Enabled"
Enter "Domain name" Name your private network
Set the starting IP address - Enter 10 ( any low number)
Set time zone
Save Settings ( button at bottom of page )
Under Advance Routing, set Operating mode as "Router"
Save Settings
WIRELESS TAB
Wireless - set to MIXED
Wireless network name - same as domain name
Select a wireless channel (default is 6)
Wireless SSID Broadcast - ENABLE
Save Settings
Wireless Security tab
Select WEP
Default transmit Key - select 1
Enter a pass phrase to generate a security code, click on Generate
WRITE DOWN THE PASSKEY ( aka, Security code)
KEY 1 should have this PASSKEY entered.
SAVE SETTINGS
On your laptop, right click on the icon for the wireless on the task bar, select "View available networks"
Select your network, it should prompt you for the passkey, you will need to enter it twice
Jan 08, 2013 | Zyxel (91-004-361002) Wireless Router
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
My Atheros AR5007 will only complete a "Local Connection, No Internet Connection" to a NetGear N600 Dual Band Router when Security Options (WPA2-PSK (AES)...ect) are selected on the Wireless...
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Feb 23, 2011 | D-Link Computers & Internet
The router is blocking access to one computer asking for a network security key which is apparently different from the password. How do you find the security key?
Hi camavery,
If you want to the security key you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security and under Security Mode you can see the Network Key or Passphrase. The Network Key serves as a password on your network to make it secure. You can personalize the Network Key so that you can easily remember it. Then Save the settings.
If this works dont forget to say thanks. Thanks for using Fixya.
Feb 05, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Error code 051099
It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
What we need to do is try creating a new connection with your system.
1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
2. Scroll over to the third page, and select "Internet."
3. Now choose "Connection Settings."
4. Click on "None" for "Connection 1." (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
5. Click on "Search for an Access Point."
6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Look for your wireless network.
7.What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
You will now have 3 options
A. GOLD UNLOCKED LOCK (No security - Tap on your network name to save the settings and begin a connection test.)
B. GOLD LOCKED LOCK
Follow the steps now depending on your option
A.
Select "OK," "Save Settings," and then "Yes." The connection test was successful - Your Nintendo DSi is now connected online.
The connection test was not successful - If the test was not successful, you will receive an error code. LET ME KNOW WHAT IT IS
B. WEP security - Your wireless network is secured with WEP and requires a security key.
Enter your WEP key
    • Error Code 51300 or 51099: This means the security code entered into the Nintendo DSi is not the same one the router is set to. Scroll back up to step #3 of this page for the step-by-step directions. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Let me know what it is.
  • Jan 15, 2011 | Nintendo DSi (0.25 GB) Blue Console
    I have just gone on to wireless and its asking for my security key? Where will i find out what my security key is????
    Hi, your security key, is the Key, that was generated in the router when you were setting up the router for first use. First, you put in your user name & password, then you go to security settings and set your WEP/WAP Key, this is the security code that must be used to logon to that network from the WiFi.
    Now if you either have an unsecured network, or an unknown WEP/WAP key, what you have to do is, Login to the Router with a browser, and get through to the security settings, and Generate a Key, now when you generate the key, copy/paste this Number to a notepad document, save it somewhere handy, say desktop. Now finish off with the router, save all the settings and reboot the router, now you are ready to logon to your wireless network, now startup the PC, and find the SSID, The name you gave your WiFi connection, now when you select, you will be asked for the WEP/WAP Key, open the notepad document and copy/paste that number you saved into the place provided, there, now you have your security set and be able to logon to your WiFi & router.
    It is all also explained in your user manual, i have included a copy below.
    http://www.retrevo.com/support/Netgear-DGN2000-Wireless-Routers-manual/id/23021ci772/t/2/
    Sep 04, 2010 | NetGear DGN2000-100NAS Router
    How do I secure my D-Link WBR-1310 wireless router?
    You can follow these steps in enabling wireless security on your router and do this steps using a computer wired to the router since once you save the settings your wireless network will be secure.<br /><br />1) Open the internet browser and type the address 192.168.0.1 to login to the router. The default username is "admin" and leave the password box empty.<br />2) Click "Wireless Settings" on the left side.<br />3) Select the Security Mode ,Enable WEP Security.<br />4) Select the Authentication ,Shared Key.<br />5) Select the WEP Encryption , either 64-bit or 128-bit.<br />6) Select the Key Type ,HEX (only A-F and 0-9 number allowed) or ASCII (all number and character allowed).<br />7) Enter a WEP key as your security password to login to your wireless later.<br />8) Press Save Settings to save all settings changed. Reboot the router.<br /><br />
    Aug 24, 2010 | D-Link 802.11g Wireless Router WBR-1310...
    How do i connect a pin number from wireless router to a blackberry curve
    To make things easier for try to do manual set-up instead and that will resolve all your concerns...Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - 192.168.1.1...Leave username blank & in password use admin in lower case...
    For Wireless Settings, please do the following : -
    Click on the Wireless tab
    -Here select manual configuration...Wireless Network mode should be mixed...
    -Provide a unique name in the Wireless Network Name (SSID) box in order to differentiate your network from your neighbours network...
    - Set the Radio Band to Standard-20MHz and change the Standard channel to 11-2.462GHz...Wireless SSID broadcast should be Enabled and then click on Save Settings...
    Please make a note of Wireless Network Name (SSID) as this is the Network Identifier...
    For Wireless Security : -
    Click on the Sub tab under Wireless > Wireless Security...
    Change the Wireless security mode to WEP, Encryption should be 64 bits.Leave the passphrase blank, don't type in anything...
    Under WEP Key 1 type in any 10 numbers please(numbers only and no letters eg: your 10 digit phone number) and click on save settings...
    Please make a note of WEP Key 1 as this is the Security Key for the Wireless Network...
    Click on Advanced Wireless Settings
    Change the Beacon Interval to 75 >>Change the Fragmentation Threshold to 2304, Change the RTS Threshold to 2304 >>Click on "Save Settings"...
    Now see if you can locate your Wireless Network and attempt to connect...
    Jun 25, 2010 | Belkin (F5D8231-4) Wireless Router...
    Having problems setting up my wireless networking adapter
    What is the brand and model of your wireless router?
    We need to know the settings (SSID, wireless security, security key/code) on the wireless router to match the settings on your xbox wireless adapter.
    On your XBOX, go to System, then Network Settings, then select "Edit Settings".
    Select the wireless network name or SSID of your wireless router. For the network mode, select Infrastructure. Select the security type if WPA or WEP and enter the Passphrase or WEP key.
    Save the settings then select Test Xbox Live Connection.
    I hope this works! Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated. Good luck!
    Feb 14, 2010 | Microsoft Wireless Network Adapter Xbox...
    New HP laptop will not connect to wireless secure network
    Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
    Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
    D-Link DI 514 Wireless Router (DI-514) Logo
    78 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
