Question about Moen 4621 Chateau 1 Handle Bathroom Faucet W/drain Assy
My single pull up type faucet is stuck and I cannot turn it on?
  • 349 Answers
Http://www.moen.com/shared/pdf/4621pt.pdf This web site has a parts break down of the faucet.
This web site has more information for your faucet.
http://www.faucet-warehouse.com/Moen/chateau/bathroom-faucet/4621p
I hope this will be help full to you in how it is put together. If you have to take it appart to work on it.
Posted on Jun 06, 2010
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
I need to replace the hot water handle
A picture, model, or brand of the type of faucet you have will be helpful as there are only three types of faucets. One hole, two hole, and three hole faucets. The one hole ones have two types: a single hot or cold, or a mixer valve to combine hot and cold into a single faucet. Each have a surface mount or wall mount version.
They all follow the same similar installation method. Turn off water supply. Unscrew supply lines from supply to underside of the faucet. a Plumber's wrench is needed or a spanning crescent wrench to remove the supply lines.
-Unscrew whole assemble from the sink.
-insert new one into the same hole as old one.
-from underneath, install the new faucet using the supplied hardware.
-Use plumbers tape (Teflon tape). It's often a white or pink silicon tape around the threads prior to screwing the supply lines back in. Re-connect the supply line.
-Open hot water faucet to maximum. Slowly turn on the water supply. Watch for leaks and drips. If any close the water supply and undo the supply leads and apply more Teflon tape.
- to apply tape. Start at the end and pull tightly, wind the tape into the threads in the direction of the turn. Do not wind in opposite direction.
-Try to turn on water again, turn slowly until it is at maximum, watch for leaks and drips.
-now slowly close the faucet and continue watching for leaks and drops.
If the faucet is fully closed and there is no leaks, you've done a good job... basic plumbing 101.
Now if your pipes are solder types and not screwed in supply line, and you're not confident with a torch or have little experience, ask for help from a friend who has some torch knowledge or hire a plumber. It is simple to do but requires a lot more steps than simply screwing in and unscrewing supply lines.
Aug 30, 2015 | Plumbing
Delta 470 trying to remove metal pull out spray wand but it gets stuck when trying to remove and replace
Are you trying to just replace the sprayer? I replaced the whole unit so cannot help with just the sprayer.
Jun 08, 2014 | Delta Faucet Delta 470-BL-DST Signature...
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
How do you adjust temp. water luke warm? This is a single handle. Hot water set at 145.
These type faucets have anti scald dial setting that if you remove the handle you can gain access to it.
Just remove handle and mark or remember where it is and pull it out and reinsert it about 1/4 turn counter clockwise.
It has got marks on it and looks like a little gear.
May 19, 2010 | Danze & Single Handle Tub And Shower...
I just installed a new cartridge in a moen single handle bathroom faucet. Works great except no hot water. The hot water valve is turned all the way on.
try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
Jul 29, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Handle stuck
you may need a tool to pull thi out. you can get it at home depot,it's called a cartridge puller,you screw it on the cartridge and follow the directions it will come out.or just pull real hard.this is the only way to get it out,force!
Apr 10, 2009 | Delta & Single Handle Shower Faucet
Need instruction for installation pull out faucet
firs you have to remove the handle
remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
take a flashlight and determine if you need an allen head screw or phillps
remove the screw( be sure to cover your drains so nos small parts get in bottom
remove the handle
depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
whatever remove anything holding the cartridge down (some require a cartridege remover)
remove, take to store match up new and replace
by all means turn water of under sinnk good luck
TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
Jan 08, 2009 | Dmm KWC K.24.41.61.000C28 Gastro Deck...
Single handle Pioneer shower faucet will not allow enough hot water. Water comes out luke warm. How do I adjust this faucet?
its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Dec 17, 2008 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
Moen 4621 Chateau 1 Handle Bathroom Faucet W/drain Assy Logo
451 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
