Question about Parks Optical Briggs And Stratton Engine Intek 10.5hp Lawn Mower
What are the decompression valve gap measurements for a briggs and stratton engine on a toro zero turn mower
  • 2841 Answers
SOURCE: 2006 17.5 briggs and stratton ohv need specs on
Remove the spark plug. Turn the flywheel until the piston is at Top Dead Center (TDC) on the compression stroke. Continue to turn the flywheel until the piston drops down 1/4". Set the intake valve at .004" - 006". Adjust the exhaust valve to .006" - .008". You can use a pencil to know that the piston down 1/4". Just put it in the spark plug hole against the top of the piston and then place a mark on the pencil at the lip of the spark plug hole. Now measure up 1/4" and place another mark. Turn the flywheel unit the second mark is flush with the lip. The feeler gauge should be snug but move freely when adjusting the valves. Double check it after locking the rocker arm nut down.
Posted on Oct 18, 2010
freetek
  • 5568 Answers
SOURCE: Gasket for briggs and stratton
I recommend  Jack's Small Engine Repair; they have always had the detail part I needed and their prices are among the lowest.
They will probably have an illustrated parts page for your model.
Jack's
Posted on Mar 22, 2009
  • 1129 Answers
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
SOURCE: Cleaned the Briggs & Stratton Riding Lawn
kehmahcliff:
It looks like that your valves need to be maintenanced. This can be done by small engine repair shops. They should have the proper tools.
Also the "timing" of the spark and the fuel injection could be a problem. I hope this helped you.
Greetings Joe
Posted on Sep 30, 2009
SOURCE: i have a 17hp briggs and stratton vertical intek
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Posted on Apr 02, 2010
Husqvarna Z246
Husqvarna Z246 Briggs and Stratton Zero Turn Mower ...
? 1:28
https://www.youtube.com/watch?v=Ohx8nxNrgNs
Feb 23, 2015 - Uploaded by SleEquipment
Husqvarna Z246 Zero Turn Lawn Mower 46" - 23 hp Briggs and Stratton Engine: Briggs and Stratton ...
Nov 30, 2015 | Husqvarna Garden
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Apr 23, 2010 | Briggs & Stratton 66set Panzer Tractor...
Replace valve guide seals toro zero turn
i don't think those are replacable i may be wrong but i have never replaced valve guides in a small engine about the only thing that can be done is grounding the valve seats and lap the valves into the new seats..good luck
Mar 08, 2010 | Garden
Parks Optical Briggs And Stratton Engine Intek 10.5hp Lawn Mower Logo
201 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
