Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Briggs and Stratton Vanguard 23Hp starter issues
I have a Briggs and Stratton Vanguard 23 Hp less than 5 years old with less than 500 hours mounted on an old Simplicity 4041. I've had no problems other than the starter bendix seems to stay engaged. It is a new starter, with a new voltage regulator and a new solenoid. I thought maybe I wired it reversed, but such is not the case. Got a clue what is wrong? Thank you! Tim
  • yeotimman Jun 06, 2010
    Thank you miket756 starter bench checks 100%. I appreciate your time and efforts. Tim
    President:
  • 2,702 Answers
Take the starter off and give the bendix a realy good clean up and then splash some oil on it,,,they get very dry and sticky at times,,,you can test the starter uasing some jump leads stand on it though, dont hold it in your hands as it will spin out of your grip
hook the black lead to the caseing and tuch the red lead on the starter battery stud,,,it should spin up and strow the bendix out as soon as you take the lead off the bendix should slid back in if it dont oil it till dose also check the starter relay it could be sticking on holding the starter in
Posted on Jun 06, 2010
Testimonial: "Thank you miket756. Brand new starter that 100% bench checked. Cannot understand what problem is, I appreciate your time and efforts. Tim"
  • Michael Thorpe
    Michael Thorpe Jun 06, 2010
    hi its miket756 again
    have a look at the flywheel ring gear it may be that this ring gear is grabing the starter bendix and jaming it in gear and not letting it slide out of gear when you let go of the key,,,also try the starter solenoid with a light buld to check it realy is switching the starter off and not sticking on,,,
    Brigadier General:
  • 4,088 Answers
The starter may need shims between the engine and starter to permit the relative gears to release. Compare the two starters, if you still have the old one, for shaft length and bendix construction. Hope this helps!
Testimonial: "drallim, Everything checks out, cannot believe I've received 2 bad solenoids from NAPA. I had bought a new one and exchanged it because it seemed the switch was sticking. Still have not solved problem. Thank you for your time and efforts. Tim"
  • 1 more comment
  • drallim Jun 06, 2010
    The starter should hang below the flywheel ring gear, so that it shouldn't stay engaged due to gravity. Does the bendix couple gears through inertia or due to the mechanical action of the solenoid? Can you tell if the starter motor is running when engaged? Try taking the solenoid small terminal wiring off and just jumper the two heavy terminals to run the starter. Does the bendix now release? The point here is to isolate the problem to either electrical or mechanical. What was wrong with the old starter and did it exhibit the same bendix problem? Is it possible to reverse the solenoid position? Take the top cover off of the engine so that you can see what is happening. By hand, push the starter gear into the flywheel gear--it should disengage easily. If it doesn't, look at the condition of the flywheel ring gear--are the teeth chewed or burred? Does the starter seem to be too close to the flywheel? Hang in there!
    Another thought, remove the starter electrical connection, then try the key--does the solenoid 'click' every time you go to start? If it clicks only once, then investigate the solenoid wiring as that would suggest a self-latching relay. Can the solenoid be reversed in it's position? Keep on trying!
  • drallim Jun 07, 2010
    Did some on-line research. The starter relay is not sensitive to position as I thought. There is just the solenoid coil with one side tied to ground and the other side to the ignition switch (which sends +12 volts when key turned to start. Remove the coil connection and check for 12 volts all the time--suspect a bad ignition switch. Hope this gets things running!
  • 394 Answers
HI,
Just a suggestion. Are you sure the gear on the starter motor has the spring in it to push the gear away from the flywheel after you release the key. ??
Wayne
Posted on Jun 07, 2010
My Briggs 23hp ran out of fuel is there a reset switch as the engin will not start anymore.
I would be checking low oil level as there is a low level oil switch that switches off when you run low on engine oil.
May 10, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
How do you remove the starter on Briggs & stratton V-twin 23 hp
You may need to remove the engine top cover to get at it maybe not...It is attached at the top of your engine where the fly wheel and fan are located..it spins the flywheel..if your engine is vertical it will be vertical if horizontal likewise.it normally has only two mounting bolts and a small wire or two..just remember where the small ones go..pretty much a easy job make sure you disconnect the battery or you will get sparks at the starter...good luck
Jul 23, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Sep 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and...
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Aug 03, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I am considering purchasing a used Exmark with a 23 HP Vanguard engine (~70 hours on the engine). I've not been too pleased with Briggs (have one on my John Deere garden tractor - hot natured and...
yep its a briggs and normaly there very good ploders
if your john deere spluters and back fires it needs a good looking at check the valves first,,,a hand full of bolts and the heads off and if your carfull you can still use the same head gasket again,,,also check the carb there very finiky and need to be kept clean the air filter is a joke,,,but clean it anyhow and they like new plugs,,,every ten years or so? iv worked on 100s of brigss and stratons/vanguard. there good engines but there ploders not sprinters there ok in a tractor but no good in a tank there to darn slow
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
New Vanguard starter only spins slowly even when
Did you ever get an answer? Mine is doing the same. I think the starter is toast. I bought a new battery, but spins just as slow. Thanks Ken
Jan 30, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
1,994 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
