Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Do I have to drain my 24 ft round above ground pool to install an intex salt-chlorine generating system? I have just opened he pool and the ph and chlorine levels are where they should be.
  • 297 Answers
No need to drain go to the intex web site and look up your pool size for the starting amount of salt you need.
After ading it run your filter for at least 24 hours before trying to generate use this web site and click on the english version for pump 8110 once it downloads go to page 13 14 15
to find the salt amount you need
chlorinehttp://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on Jun 15, 2010
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
We have an Intex above ground pool that takes salt and converts to chlorine. We filled it about a month ago and all was fine for a few weeks, then in the past week the water began turning green. We have...
Intex chlorine generators are very low output generators that fail very often. There is a reason they are so cheap. They do not work well. When using a chlorine generator, it is important to test manually for salts and free available chlorine on a daily basis. Just adding salt because you have a generator will not make your pool manage itself. In order to get the most basic chemistry under control, you need to test for alkalinity, calcium, pH, and free available chlorine.
If you do not have the ability to test these things, spend $10 on a 7 in one test strip that will give you this information.
Note: Chlorine generators have more negative aspects to them than positive. There is not a cost savings as advertised with these units. It actually costs more money, and takes more time to care for. The salt is very corrosive to the pump and filter system as well as the pool itself. The long-time cost would be cheaper to run a chlorine or bromine pool.
May 02, 2011 | Intex Automatic Salt Water System for ...
I have an above ground pool 18' round 52" deep. I purchased the intex saltwater system. I have had it run everyday for 8hrs a day and the ph is high and reads no chlorine. What to do?
Salt generating systems cuase pH to rise over time so you generator appears to have been working. What is the salt level in the water? Perhaps your pool is low hence no more chlorine generation.
Aug 27, 2010 | Intex Automatic Salt Water System for ...
I have an intex salt water system for my 16ft round pool. My FC level is reading 0. Should I proceed to boost the system. PH is high also. Thanks.
run your generator for the full 12 hours. You need some serious sanitizer or you will be going green soon.
Also add some stabilizer so that the chlorine level does not drop so easily
As for the ph hit it with some ph down
It wouldnt hurt to get a bottle of non foaming algacide also
Jun 24, 2010 | Intex Automatic Salt Water System for ...
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the...
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Jun 07, 2010 | Intex Automatic Salt Water System for ...
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
I have a 18ft x 52 intex pool with salt water chlorinator.green
although you may or may not have enough chlorine in your pool you must also realize that a pool need turned over at least 3 times a day.
an example is if you have 7000gl of water and a 2000gph pump you need to filter at least 10 hours or so.
More important than chlorine is the actual circulation of the water you can have all the chlorine in the world but if you do not have the circulation the water will become cloudy or green this also happens when you have no swimmers for days at a time
the filtration time is over and above the chlorine generating time your 4 hours a night for generating chlorine sound like you are guessing sometimes it may be 4 and sometimes 2 or 6
it depends on # of swimmers a day sun and what was in the pool to start
It is important to have a test kit for ph and chlorine and keep chlorine at 1.0to 1.5 now set your ph
ph will rise and fall with your chlorine level one you have them set good at the first time then ph should stay safe enough and re level as chlorine is kept right
also remeber that the wrong ph causes more problems than wrong chlorine levels
Also make sure your salt is no more than 3000ppm and no higher like some people recommend and no lower than 2500 test kits are available for 10 dollars
all of this can be found on intex.com either in a video or pdf files for water capacity and approximate time for generating chlorine.
to be sure always use test kits
Jul 12, 2009 | Intex Automatic Salt Water System for ...
High ph, algea, salty taste
You are going to need to buy chemicals anyway (acid for sure and probably algaecide) so find a good pool store tech and have them test your water and recommend the proper doses.
In summary though, you should not taste the salt in the pool and being able to means the salt content is to high. Chlorine generators will not work if the salt is to high and the fix is to drain water and dilute the remaining water until the salt content is no higher than max. No chlorine could explain the algae.
Generators also cause the pH to rise over time so you will need to keep acid on hand to counteract that.
Jul 05, 2009 | Intex Automatic Salt Water System for ...
I have an intex chlorinator and an intex 24' x 48" round pool. I added only 250 lbs of salt, but the table said 290 lbs. I never got a "low salt" reading. When the water level got low I added water and...
high chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Jun 27, 2009 | Intex Automatic Salt Water System for ...
Intex automatic salt water system died can I chlorinate the salt water.
Yes you can. Liquid would mimic your salt water generator in that it will slowly raise your pH over time. Switching to tablets would do the opposite to pH.
Jun 16, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
379 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
