Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain saw carburator settings for husqvarna 61
After cleaning air filter and carb, I cannot get my chainsaw to even fire. There is lots pf spark and the gas is flowing back to the tank. The low and high carb settings is what I thinks is the problem but I have not found the right combination. thanks
    Brigadier General:
  • 4,088 Answers
Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow the engine to warm up, then pull the throttle full on. Turn the H jet screw CW until the engine starts to speed up, but still 4-strokes. Proper adjustment occurs when the engine is 4-stroking, but immediately 2-strokes when cutting. This gives best power and lowest heat. Release the throttle and adjust L jet CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Posted on Jun 17, 2010
61 fires up then dies,seems to be good spark and gettin fuel
If the saw has good compression and spark (check them with proper gauges) check the fuel lines and fuel filter. If this all checks out, then the issue is probably the carburetor itself.
Feb 08, 2014 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I need to know if the Husqvarna 136 is a 2stroke or not. And also what a company would do to my chain saw if i got a service done on it?
Your saw is 2stroke, the mix is 50 to 1. a service would mean a new spark plug, clean the carb. and air breather filter, sharpen the chain, check the bar and chain for wear or damage and advise you. Stephen
Sep 24, 2011 | Husqvarna Garden
Erratic idle. it sometimes races and then settles down in idling.
chain saws get dust and debree allot faster than lawnmowers in their carburators and need to be taken apart and either cleaned or have a nw carb kit its just new gaskets . gasoline also oxyadizes after 30 day and that can leave behind a yellow film that will clogg the tiny holes in the carb. If you are adventerous and patient you can get a new kit and replace the parts yourself if you yake it apart take some pics of where things are and it will help when putting back together. there are lots of torx bolts and some brands use allens screws . but i would most likley say that your carbe needs to be cleaned put a new air filter and spark plugg in to hope this helps if you have any questions or help doing this yourself i will assist you
Jan 18, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 61 lots of spark fuel is getting to carb cylinder is dry wont start would comprison be bad?
Two stroke engine have a reed valves, or something like it, that prevents exhaust pressure from causing the gas to back up.
Because of long idle times in the winter, if you don't use a fuel stabilizer, the gas dries up an leaves a sticky varnish residue.
This not only plugs up orifices, but glues the reed valve either shut or open. Either is bad. So you probably have to take the carb off and clean it to remove the varnish.
Aug 26, 2010 | Husqvarna Chainsaw Piston Kit for 61...
When you start the saw it runs for a sec then u hit the gas bogs then clunks out
Start with cleaning your air filter really well
Check your spark plug for a good solid spark that goes to the electrode and not to the side of the plug - if it fires to the side replace the plug
Has anyone fooled with the carb hi/low/idle settings?
Apr 01, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
No fire craftsman chainsaw
magneto tested for spark with no positive result.
Aug 24, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 350 geting fire and gas but wont start
Have you tried cleaning the air filter? The carburetor fuel inlet may have screens plugged with sawdust as well. If you have spark and fuel and AIR you should get fire(combustion)
Frank
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
3,022 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
