Question about Whirlpool GU2400XTPS Built-in Dishwasher
Clean lite flashes 7 times and washer will not turn on. Is there a reset sequence? John
  • 523 Answers
Yes there is check under the unit for the tech sheet
Posted on Jun 06, 2010
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
CLEAN LIGHT BLINKS 7 TIMES ON KITCHEAID KUDP DISH WASHER
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Aug 08, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light blinks 7 times, pauses, then blinks 7 etc.?
Kevin
Jul 25, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
Washer will not start. "Clean"
Kevin
Jun 20, 2011 | Dishwashers
The clean light flashes 7 times then pauses.
Kevin
Jun 15, 2011 | Whirlpool Dishwashers
Clean light flasher 7 times
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Apr 18, 2011 | Dishwashers
DISH WASHER NOT WORKING, ONLY CLEAN LED FLASHING
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 15, 2011 | KitchenAid KUDE60FVSS 24 in Builtin...
The clean light blinks 7 times
Kevin
Jan 02, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Clean light blinks 7 times dishwasher wont turn on
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
Jul 23, 2009 | Dishwashers
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Open Questions:
See all Whirlpool GU2400XTPS Built-in Dishwasher Questions
Whirlpool GU2400XTPS Built-in Dishwasher Logo
149 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
