Question about Estate TGDS740JQ Gas Dryer
Running fine but no heat
Everything is working but the electric starter will sometimes start the heat and will go for a min or so and stop. After that it trys to start the heat then it turns off for a bit and it trys again. During this time the dry is still turning. help please
  • rox92253 Jul 10, 2008
    my dryer is tgds740 pq1 this was the closest model # after taking off the back I can see the gas kick on and stays on for several min. long enough to get pretty hot...but then it shuts down. I checked the few sensors in the back and wiped them off...I am not sure is there a thermal coupler like in a hot water heater? I haven't turned over the dryer yet! thought I would get some input. any suggestions? thanks roxanne
  • lesliecoons Dec 18, 2008
    I have the same problem (heating) as above with my dryer Model Estate Brand T6D5740PQ1. Where are the solenoids located?
    Novelist:
  • 184 Answers
YOU HAVE A SOLENOID (COIL) ON THE VALVE THAT IS HEATING UP AND BREAKING CONTACT INTERNALLY. WHEN YOU BUY THE COILS, THEY COME AS A SET SO YOU WILL REPLACE BOTH OF THEM.
Posted on Apr 10, 2008
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
Headache
You might need a new starter what's happening is when the starter heats up it won't start up again until it cools off
May 30, 2013 | Vehicle Parts & Accessories
Car stalls after changing starter on 2003 honda accord
check your connectors sometimes they don't seat all the way top the coolant off maybe an air pocket is causing a sensor to not work i had a car that needed bleed of air to get it running right
Mar 02, 2013 | Cars & Trucks
2005 grand caravan. running fine. stopped at gas station and filled up. turned the key and won't start. all lights work. bell dings when keys are put in ignition.blowers work. everything runs but won't...
Try cleaning your battery terminals with a wire brush or sandpaper. You will need the proper wrench for this precedure. Retighten & start. If this fails, try taping the starter with a screwdriver. Sometimes this will free up a sticking starter selinoid. If this fails you may need a new starter. Hope this helps. Good luck!
Aug 21, 2010 | 2005 Dodge Grand Caravan
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
1992 Regal sometimes won't start after stopping.Have to wait about 5 mins to restart.This is an intermittent problem. It has also stalled on me waiting in traffic at idle. Had to wait 5 mins and then it...
Check routing of fuel lines (too close to heat source like muffler, catalytic converter - check for missiong heat shield around exhaust). Sounds as you are having a fuel vapor-lock.
Could be ignition position sensor coil (not ignition coil) but not so likely.
Sep 22, 2009 | Buick Regal Cars & Trucks
My 2001 case 586e forklift will just quit running
check the fuseable links arround the starter
somtimes they seperate when they over heat and the ruber contracts when they cool down
if they are cooked they will pull apart fairly easily when hot
Sep 16, 2009 | Milwaukee Tool Case Heat Gun
Jedda dies sometimes
What is everything? does just the engine stops running, or does the heater fan and headlight stop too, does the the radio and parking lights stop working? does the starter engage after it stops? If you answer this question I will be able to help you.
Aug 24, 2009 | 2000 Volkswagen Jetta TDI
Engine stalls.
Fuel system or motor is slitly out of time
Oct 14, 2008 | 1994 GMC Safari
Estate TGDS740JQ Gas Dryer Logo
273 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
